![]() | Home > General (L405) > Don't overlook the obvious. |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3817 ![]() ![]() |
Glad you got it sorted, but Your TPMS wasn’t working as well then ? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Mariana Black Member Since: 30 Jul 2014 Location: Stockton-on-Tees Posts: 89 ![]() ![]() ![]() |
Hi
Mine does on start up - flashes on the dashboard whether it’s set for light load etc - you can also go directly into the menu and it tells you the pressure for each tyre. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 ![]() ![]() ![]() |
Doesn't have TPMS as far as I'm aware. Certainly the valves are standard rubber type but monitoring might have been useful in this instance ! |
nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 233 ![]() ![]() ![]() |
Has anyone noticed that recommended tyre pressures change whilst driving? I can only assume the software detects the type of driving e.g. motorway vs. town traffic, and adjusts accordingly. |
