Home > My Range Rover > First FFRR 2004 4.4 v8 |
Muzzychris Member Since: 03 Jul 2016 Location: County Durham Posts: 27 |
4th Mar 2019 4:13pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3062 |
welcome and lovely car/colour!!
4th Mar 2019 6:26pm |
£3000 ouch haha, that’s brilliant thanks I will check them all this week. I’m hoping that going into this with my eyes open will soften the blow when something inevitably goes wrong! For the mean time I’m just enjoying everything working! The gearbox seems perfect is it worth servicing it as you hear a lot of horror stories about them destroying themselves shortly after? |
4th Mar 2019 6:31pm |
If there is no service history, I would get the gearbox oil done as well as the diffs and especially the Transfer box oil done at the same time. The last 3 are not as expensive as the main gbox but at that mileage well worth doing for peace of mind, especially the transfer box.
4th Mar 2019 7:07pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 837 |
What difference does running it on lpg have on the chain guides ?????? I just dont get this comment lpg has nothing todo with chaun guides. Yes they are prone to going but it has feck all todo with lpg.
4th Mar 2019 7:29pm |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2152 |
Most importantly, it’s green
4th Mar 2019 8:23pm |
I understand it’s the heat that makes them brittle and Lpg makes the engine run a bit hotter so can speed up the brittle process, so I’ve Been told. Happy to hear otherwise as I’m just an amateur engineer who’s learned the hard way. |
5th Mar 2019 12:12am |
LPG has no effect on the heat of the engine what so ever considering the temp petrol burns at in the engine lpg burns only slightly hotter the biggest risk to these 4.4 engines is the engine thermostat at 108 degrees extremely hot cooking everything rubber or plastic hence why the stat mod to 80 degree is so important and popular. |
5th Mar 2019 10:25pm |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 520 |
Definitely do the lower temp themostat mod, makes everything so much calmer and stops the engine smelling (as someone on here once described it) like Chernobyl after it's been on even a short run.
6th Mar 2019 9:04am |
How do I do that, is that through the IID tool. I don’t have one yet but going to buy one! |
6th Mar 2019 9:35pm |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 559 |
+1 for PCV valves - if you take off the plastic engine cover there are two large rubber hoses towards the back of the engine - if they feel soft and squishy then you'll need to replace them and check the PCV valve.
6th Mar 2019 11:54pm |
