![]() | Home > Technical (L322) > Help / guidance needed for IIDTool suspension calibration |
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Take it back??? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Fair comment, just getting to the stage where I feel one thing gets fixed and it comes back with another issue.
As it is all over the place on every corner, suggest follow the full calibration procedure from GAP (in the manual) .
Ian Donkin Member Since: 17 Aug 2010 Location: A Yorkshireman in Surrey Posts: 107 ![]() ![]() |
If your IID Tool is the bluetooth version, it has a guided calibration option that would be worth running through; it's very easy to use and takes no more than 10 minutes.
Hi there.. Just a quick update. The rear right sensor was held on with two cable ties. I've replaced this with RQH100030.
Page 98 onwards of the iiDTool manual |
Morning.
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
Being a non tech and very stubborn, I have been fighting with the tool to, just untill the moment I remembered an expression on here " RTFM". I sat down behind the pc did some propper reading ( the manual is pritty simpel) and solved my problem. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
as advised above, relax and read the manual,
Afternoon chaps.
that looks like its gone into extended mode...is the brass compressor vent clear?? |
Hi Stan.
certainly, i would run through the height modes several times and then re-check heights and adjust. |
