Home > Maintenance & Mods (L322) > Fault Code Help?
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Fault Code Help?
Hi all
Has been a while since I’ve been on. 2004 TD6. I’m using an icarsoft reader. I know this RR has always thrown up random faults, but wonder if anyone can help?
Car had gearbox refurbished 1 year ago (8000 mile).
Noticed 2 small oil leaks but not took a lot of notice as wasn’t a lot and no drips etc. Came out from work and started car and got the “Trans fail safe” message up (I nearly always get HDC inop even tho it’s had 2 new batteries)
Whilst ticking over the message went from the screen. Drive car home with no issues and drove well. Turned car off and “Trans fail safe” flashed up again with a bong....
Restarted car with no messages at all.
Just put the icarsoft on it with the intensional of running it up to 40 degrees and get under to check oil.
Cleared all the faults like always (there’s always a list although everything works on car!)
Drove car around block. No messages and good in all gears still.
Re diagnosed and have a fair few faults again? Normally I get a week before they start creeping back.
2 questions, 1 Could it have just been a low battery on a cold night? And 2 would anyone consider any suggestions if I list codes?
Thanks so much in advance
Tel Accept, some days your the pigeon, some days your the statue!
Post #507475 5th Mar 2019 4:47pm
and the fault codes are .... ?
(some can safely be ignored, which is why I ask) .
Post #507486 5th Mar 2019 5:43pm
Boydonegood
Thanks so much Joe. Accept, some days your the pigeon, some days your the statue!
Post #507496 5th Mar 2019 6:30pm
Boydonegood
Glow plug device or relay
Transfer gearbox CAN error
Steering angle plausibility
EBV function fault received from ABS ECU
Air quality sensor line fault
Ventilation fan PWM control voltage fault
Right seat temperature sensor fault
Evaporator sensor fault
Left seat temperature sensor fault Accept, some days your the pigeon, some days your the statue!
Post #507497 5th Mar 2019 6:32pm
Boydonegood
Swapped pics for text! Thumbs Up Accept, some days your the pigeon, some days your the statue!
Post #507499 5th Mar 2019 6:34pm
Probably just an occasional comms error that threw up the fault
However if it keeps giving you TRANS FAIL SAFE then further investigation required
(note: the car will tell you about such a fault again when you turn off the engine)
Requires investigation!
But these 'could' both have been caused by voltage issues. If you are going through batteries, it may be worth doing a battery drain test to see what happens when the car shuts down (if it does!)
Testing Battery Drain Instructions Help
Not sure which evaporator this refers to .
Post #507545 5th Mar 2019 11:01pm
Boydonegood
Joe you are an absolute star. Thank you so much! Will do the battery test as you say.
Your a diamond.
Thank you. Accept, some days your the pigeon, some days your the statue!
Post #507546 5th Mar 2019 11:04pm
