![]() | Home > Technical (L322) > TD6 not starting - am i right this is the starter motor...? |
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 ![]() ![]() ![]() |
Did you measure at the starter connections? is there voltage if you go on III? |
Richycsurfer Member Since: 18 Nov 2018 Location: Plymouth Posts: 44 ![]() ![]() ![]() |
At which connection? The big one has a constant R wire from the battery and the other is the small one (from ignition switch/immobiliser) which does go to 12v when turned to III. |
Are you sure you have a good battery holding a full charge? How old is it.
The battery may not be perfect, it is a year or so old but have suffered some flat batteries recently with the cold weather and cabin pre-heater, however with jump starting (other car running) i hoped i was ruling it out.
The starter is earthed by the fact it is bolted onto the engine block.
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 ![]() ![]() ![]() |
Starter on my TD6 failed at around 180k miles.
I've pulled my battery out to try my luck getting it changed FOC at ECP due to it being only 2 years old. It's reading 12v out of the car which is definitely low but whether they'll change it for me is another question. The car was charging at 14.1v when running.
you just need to apply battery voltage to the output of the solenoid to the motor.
^ +1 Have to agree |
I did get a new battery - well done ECP on the warranty. They didn't even test it which was nice. There list price for this bosch is now something like £350.
nice new battery is always helpful!
All sorted... Very quick postage from the eBay starter motor £80 next day. Its a smaller body unit presumably from a different stock.
