Home > Technical (L322) > One touch window lift |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2929 |
I don’t have one touch window lift and I can’t find it in the IID to install it. Can anyone point me in the right direction ? |
6th Mar 2019 7:54pm |
It didn’t work when I bought it.
6th Mar 2019 9:01pm |
Ok- tried that. Didn’t work! |
6th Mar 2019 9:22pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1194 |
Sorry about that. I'm not sure if your model has the same switches as mine, two clicks when pushing or pulling. Maybe a subtle difference in model years.
6th Mar 2019 11:19pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 819 |
Try engine running and all four doors closed. Open the drivers window first and hold the button down without releasing it, hold it down for about 10 seconds and you should hear the relay reset itself with a soft click. If that doesn’t work try holding it down for a bit longer. Then repeat in the opposite direction to set the window close function, if that works do the same for the other windows.
7th Mar 2019 12:31am |
It’s only the drivers door that does it. All the other windows are ok.
7th Mar 2019 7:51am |
Andy
7th Mar 2019 9:38am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
I used Faultmate to change mine. Ron B. VK2OTC
7th Mar 2019 11:33am |
