Home > Maintenance & Mods (L322) > Fuel Additives...
Page 2 of 4 <1234>
Weegie
Am I correct in remembering that if you use 2stroke it should be mineral and not synthetic? John
GAP iiD BT-Sold
Post #508342 11th Mar 2019 9:35pm
Mineral Thumbs Up
Post #508343 11th Mar 2019 9:39pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
I use Dipetane regularly now after a sticky fuel pressure regulator in the high pressure fuel pump was causing havoc. I could run it as long as the engine revs stayed above 1200 rpm. Below that it went straight into limp mode. I was told the only cure was a new pump at €1600 plus labour.
A heavy dose of Dipetane and a half an hour Italian tune up and all was well and still is over a year later.
Ultra low sulphur diesel, I believe, is the problem. A bit of extra lube in the fuel can't hurt.
Just my 'two penneth' 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #508361 12th Mar 2019 12:02am
Jri711
United Kingdom 2010 Range Rover Vogue 4.4 V8 Santorini Black
So ok t2 is good for our td’s & we should use mineral not synthetic, but dose anyone know at what ratio?
Post #508475 12th Mar 2019 8:41pm
Grofus
200:1 is about 0.5l per tank full.
The Dipetane I use is the same ratio. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #508478 12th Mar 2019 8:49pm
rar110
I think additive makes a difference and I use BP. I also think induction cleaner helps the motor. I use Revive.
I have used the following products. I don’t think they are the same or do the same thing.
 ______________________________
Post #508501 12th Mar 2019 11:22pm
obviously Australian product's... Mr. Green
Post #508523 13th Mar 2019 8:42am
gettingold
Good job the lids are on those bottles Mr. Green
Post #508525 13th Mar 2019 8:59am
supershuttle
Tesco is my nearest garage, I've used both diesel and Petrol from there for over 40 years without any problem. I did try some additive in my diesel RR (previous to this one) put it in religiously (even bought a measuring thingy) I'm not sure it made any difference. But all the arguments are of the "is there life after death" type - no one really knows. Geoff
Post #508528 13th Mar 2019 10:09am
EmiratesA380 wrote:
Just don't ever use super market fuels - injectors will fail at 130K/160K - fact
not fact, but an opinion....
Post #508534 13th Mar 2019 10:37am
rar110
I had to post the pic upside down so you mob in the northern hemisphere could see it properly. 😆 ______________________________
Post #508535 13th Mar 2019 10:38am
Laughing Thumbs Up
Post #508536 13th Mar 2019 10:41am
supershuttle
I'm not entering the debate, the only "fact" I know is what I posted me, SWMBO, son and daughter use Tesco fuel all the time and haven't had any problems - the kids aren't old enough to have been using it 40 years (43 to be precise, today is my wedding anniversay) I taught SWMBO to drive back in the day so she doesn't have 40 years with her own car either. The stuff I used in the Diesel was BG422 or is it BG244 or BG 224 or BG 442 who knows, who cares. Geoff
Post #508537 13th Mar 2019 10:42am
congrats to you and your wife on your wedding anniversary geoff.. Wink
i also dont want to enter this debate, but, i to have been using supermarket fuel from as early as the mid seventies..i have had no engine problems at all..
i beleive supermarkets supply about half of the UK's consumption so you'd think if their fuel was inferior and caused engine problems then someone would have noticed by now..
Post #508541 13th Mar 2019 10:53am
rar110
Thanks Stan. Not easy to fix pic orientation on a phone. ______________________________
Post #508546 13th Mar 2019 11:30am
Page 2 of 4 <1234>
