Home > Maintenance & Mods (L322) > OSR Caliper sticking
supershuttle
I just had the front discs and pads done because as well as a wobble on slowing they were also the cause of a bit of squeaking. The wobble has gone Thumbs Up but the squeaking persists so I investigated and found the OSR caliper sticking slightly, warm after a long drive while the other is cold. So my question is has anyone had long lasting success by cleaning and lubing or should I just bite (expensive on a 5.0L S/C) the bullet? Geoff
Post #508652 14th Mar 2019 9:11am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Just had my near side rear replaced and found Matlings offroad in doncaster to be the keenest price Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #508653 14th Mar 2019 9:16am
Fraynizzle
United Kingdom 2005 Range Rover Vogue Td6 Java Black
My TD6 has the ATE callipers I had a sticky rear caliper so rebuilt them with new pistons and seals. Fixed it for a while buts it’s back. I’d just get a new caliper... more cash but should last a lot longer.
Post #508660 14th Mar 2019 10:10am
supershuttle
I tell you what dolph - Kildare to Doncaster is some trip - BTW thanks for the advice, more expensive maintenance Geoff
Post #508663 14th Mar 2019 11:00am
Shaun
England 2011 Range Rover Vogue 4.4 V8 Orkney Grey
Fixed mine by ordering a new piston and seal kit from Brakeparts.co.uk and refurbished myself. 2004 TD6 - Gone
2011 4.4 TDV8
Post #508673 14th Mar 2019 1:13pm
dolph34
Hi Geoff , just a quick jaunt across the pond ( while we still can !!!) . I have been informed that the early calipers do fit and work no problem ( and they are cheap as chips) but i decided to stick with the 'correct ' part.
Regards, John 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #508695 14th Mar 2019 3:53pm
kooky_guy
My OSR started intermittently seizing shortly after having the discs and pads replaced.
I ended up just replacing both the rears but it was expensive. It seems to be a bit hit and miss whether they can be reliably overhauled or not, and I didn't want to have to keep going back and forth to the garage. 2010 4.4 TDV8 Vogue SE
Post #508710 14th Mar 2019 4:23pm
Jri711
United Kingdom 2010 Range Rover Vogue 4.4 V8 Santorini Black
I’ve had this happen on the rear of both my l322’s & on both occasions I’ve removed the caliper pumped the piston to near fully out, gave it a dam good clean with brake cleaner, a little lube with engine oil pushed the piston back in and refitted. Worked both times for me , so maybe worth a go as costs nothing but a little of your time if your confident enough to try.
Post #508732 14th Mar 2019 6:28pm
supershuttle
Yep just rang the Indie, just over 620 quid for the one side including new pads, I had the other done a while back. I think someone suggested getting them both done - should have listened Very Happy Geoff
Post #508758 14th Mar 2019 9:38pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
I'd strongly suggest nobody uses engine oil to lubricate any brake pistons or seals as it is incompatible with brake fluid and is very likely to cause the piston seal to swell / distort significantly. The caliper may continue working for a while, but there's no telling whether it will end up leaking or jammed. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #508792 15th Mar 2019 10:10am
