Home > Maintenance & Mods (L405) > Oil Level Overfilled ? |
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 |
I certainly wouldn't remove the sump plug, that won't end well ! I had a similar issue with my SDV8 which has an oil suction tube. Bought a 4 litre Silverline suction pump which worked perfectly and took less than five minutes. Can't remember if it was from Amazon or ebay. So first thing is to check if you have a suction tube on the 5.0. If so, this is definately the way to go. |
4th Mar 2019 10:40am |
nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 231 |
Lidl are currently selling oil drain kits which have a small electric pump to suck oil out of the engine. A lot easier than crawling under the car and draining the sump! They might have a few left, as they were on sale a week or two ago - 3 year warranty etc. |
4th Mar 2019 1:06pm |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 |
Thanks for the comments guys, wheres the suction tube likely to be on the 5.0 motor, what does it look like please?
4th Mar 2019 2:12pm |
Anyone know where the suction tube is on the 5.0 S/C, please?
6th Mar 2019 8:47am |
Just checked it again after posting the last message and sure enough now says oil level ok,
6th Mar 2019 8:57am |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 |
Interestingly I foolishly checked my level after a suspected oil leak, and it was low, so I stopped it up, now it's on maximum and I get this smell of burning oil in the cabin.. i wonder if i over filled it and now its causing this burning smell....? |
16th Mar 2019 8:37am |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 |
errrmm 2 questions - why wouldn't removing the sump plug end well ? - never had problems with numerous other cars but admittedly never tried on the SDV8 - so what's the problem? also Wheres the drain tube on a SDV8 or is it obvious? thanks |
16th Mar 2019 12:17pm |
As I understand it, Carlos only wanted to remove a small amount of oil as the dipstick showed over filled. Getting the sump plug back in would be tricky to say the least ! |
16th Mar 2019 3:47pm |
Ooops, missed the question re suction tube. Its at the front left hand side of the engine with a small black plastic cap which screws off in about one revolution. Easy to get to and fairly obvious |
16th Mar 2019 3:54pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3672 |
With the cap off and pump connected..
16th Mar 2019 4:52pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2300 |
Is oil leaking over the back of the engine onto the exhaust cross-over pipe? The o-rings on a pipe fitting at the back of the oil cooler housing and the oil cooler gaskets are prone to leaking due to not withstanding the heat. |
16th Mar 2019 8:54pm |
Yep got it. Just where I thought it was. |
18th Mar 2019 12:06pm |
