Home > Technical (L322) > Distorted rear camber settings?
PIMCO
Norway
Hi!
The rear suspension is eating tires as the outer edge of my right rear tire is badly worn. I guess technically it's excessive positive camber - but could this really just be misalignment? The suspension seems firm otherwise, but the degree of wear is making me suspect something is defect.
Was planning on getting a four wheel realignment, but thought I'd check in with the experts first.
Anyone with experience with similar issues that could point to potential culprits?
Post #508289 11th Mar 2019 5:07pm
Could be just alignment, but more likely a worn out upper or lower or both hub joints, or the toe arm.
First port of call would be an MOT mechanic who knows how to test. .
Post #508296 11th Mar 2019 5:34pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
My money is on the wheel having too much toe-in, ie toe arm ball joint worn or securing cam bolt has moved.
Post #508482 12th Mar 2019 8:59pm
PIMCO
Norway
Thanks for he input.
I also think toe-settings is a good bet, but how is this set? I didn't find much info on the actual adjustment procedure in the RAVE material, but judging by this picture I guess the bushing end of the "tie rod" (seems strange for a non-steer axle) has an offset (eccentric?) bolt?
What is the wear intervals on these rods/bushings vs. the actual ball-joints? I am thinking it would be kind of a waste to get the camber/toe dialed in with old/semi-worn parts (and having to redo it when/if replacing parts in the future)?
Post #508921 16th Mar 2019 4:39pm
DrRob
Just replace the whole lot. What I did. New rod, bolts etc etc
www.advancedfactors.co.uk did the lot for a reasonable price Thumbs Up
...and then get it 4 wheel aligned set in Tight Tolernace Mode Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #508926 16th Mar 2019 5:19pm
PIMCO
Norway
Hmm, does this look right (keep in mind suspension is at full drop)?
Post #509144 18th Mar 2019 11:01pm
The rubber is shot to pieces on the right (in your photo) but the only way to tell is to get the weight off it and see if it wiggles (easily...) if it does, replace.
As said above, probably time to replace the lot on both sides if they are all the same age .
Post #509145 18th Mar 2019 11:27pm
DrRob
That looks proper Censored Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #509159 19th Mar 2019 8:58am
TomCobbly
Looks like the wishbone is bent due to the corosion Crying or Very sad 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #509205 19th Mar 2019 3:48pm
PIMCO
Norway
I agree it does not look pretty - but it's primarily surface rust and the A-arm has that kink built-in already, right? Neutral
I was expecting the horrible tire wear to be newly replaced parts and lack of alignment, but the state of affairs prompted me to order up a set of new upper bushings and the "tie-rod" links.
Post #509239 19th Mar 2019 8:24pm
PIMCO
Norway
Can anyone confirm bolt/nut size on the tie-rod/tie control arm? It's hard to tell for sure with the corrosion and what not, but the best fit seems like 18mm and 20mm, but it's loose enough to where I think it could be imperial (referring to the bushing side)? Is the nut toward the front of the car welded/fixed, or is it an independent through bolt/nut?
Also, any hints as to how to lock in place the bolt on the tie-rod end while unscrewing the bolt? I think the bolt shaft is supposed to accept a 10mm socket (?) for clamp-down, but mine is busted and turning inside the socket.
Post #512044 14th Apr 2019 12:53pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Definitely all metric. 18 & 20 mm sounds right from when I did ours.
No welded nuts - just very rusty - lol. The nut end of the bolt has a "cam washer" to adjust the toe-in.
The hub end has a 10mm hex as you say - for holding the joint thread while undoing the nut.
I didn't manage to get a socket onto for space reasons, but I did get a short 10mm ring spanner on it.
10mm 6 pointed ring ( rather than 12 point) would be better to avoid the risk of "rounding off" of the hexagon on the joint thread. The nut was very tight on the threads.
If your hexagon is broken / damaged, can you get a small disc cutter ( eg dremel or similar) or grinder in to cut the nut off or thread off? Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #512048 14th Apr 2019 1:17pm
I had to grid/hacksaw my 10mm nut off the toe arm, whole thing just going round and round. OK if replacing the whole thing.
Why they don't put:
1. A decent sized nut on the end
2. Large spanner slots on the joint (like with the drop links on the front) .
Post #512050 14th Apr 2019 1:37pm
