![]() | Home > Technical (L322) > Dodgy rear drivers window |
noddy5vogue Member Since: 21 Jan 2011 Location: Blackpool Posts: 38 ![]() ![]() ![]() |
Had a quick search and could see anything relating to the problem my ffrr2003my has ,Only happens occasionally but the rear drivers window will wind its self down and will have to wait about 10 seconds before i can wind it back up from the front switches happened twice last night on the m6 ,children were a sleep in rear and windows locked off from front to stop them playing with them. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
something is activating the window, maybe a loose connection or water ingress shorting the switch. ... - .- -.
check the multi plug at the bottom of the drivers A post,its right where the LCM is,check to make sure you have no windorscreen leaks here and its dripping, had any probs with your lights |
Thanks for your replies will have to wait till the weekend when i can have alook in the daylight as regards problems with the lights i sometimes get a warning for sidelight which i believe is a bad connection and goes on and off depending on which pothole we hit |
