![]() | Home > Maintenance & Mods (L322) > Td6 thermostat recommendations. |
| wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 808
More likely the egr thermostat. Easy to do as the top front of the engine. Get one for a BMW, there are 2 types of fitting on the BMW so be assured if you get the wrong one the ends are removable so you can swap your old over.
| GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165
I was aware that the EGR 'stat could need doing too but from what I have read a lot of people did that first then still had to do the main 'stat.
| stuart_2006 Member Since: 18 Jul 2018 Location: Holsworthy, Devon Posts: 136
"the ends are removable so you can swap your old over"
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6432
Main and EGR thermostats:
I did have the EGR stat off once before and I had a replacement one ready to fit but it had the wrong end (ribbed). My son used that on his E46 320d.
Have you tried Duckworths ? .
I read on one of the landyzone pages that one alternative to replacing the main thermostat is to fit a second thermostat in the top radiator hose. The thermostat to use appears to be one like this (www.ebay.co.uk/i/293644625064) from a Renault 4, and this appears to be a 'common' mod for the Freelander TD4 as well where replacing the main thermostat is a right pain (although easier than the TD6).
| kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 229
I run this mod in the winter, found when got the car three years ago in the first winter even after a twelve mile run the fbh was still running (reckon gauge got to be third of way up before it cuts out) so after egr stat and then engine stat (engine stat of the bay) it was no better so ok fit genuine stat and got to say the £80 it cost might as well stopped in my pocket, ran just the same temp this is with no fan or shroud so bit of internet search came up with freelander mod, got my local factors to order up a reno stat cut the clip off top hose engine end pushed stat it hose secure with jubilee, same run now in winter sees gauge dead in the middle and top of rad maybe just warm,picked up a s/h top hose and swop over in summer only need to drain 5 liters out of rad to do the job well worth the bother I think. |
Thanks kds2. Why do you swap the hose back in the summer? Do you find the thermostat restricts the flow too much when the weather is warmer?
It is the pinky-orange stuff for the TD6 .
Thanks Joe. That looks like the OAT stuff.
That is the theory..... Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
I change over in spring just to be on the safe side stuart_2006, did have to have a run down to wife`s sisters last year after I had changed over and that day saw the outside temprature about 10c but even after 130 miles at mostly 70 mph the bottom of rad was only just warm with cabin temp set at 22c, couple of other reasons for doing the mod most of my trips are often only three or four miles so engine never gets chance to warm up in the winter other thing being after doing remote switch on park heating most of heat generated by the fbh now goes to help defrost and heat the cabin, I always try to keep engine revs below 1750/2000 rpm till I see the temp gauge about third of the way up so not to stress a cold engine. |
| mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425
Just purchased the rover stat to do the TD4 'mod' on my TD6 . which way does the stat fix ? i assume the coolant flows from the engine to the top of the radiator . |
