Home > General (L405) > Land Rover Approved 165 point check.
So
Hi guys
I've just bought a used L405 which has had the above check. However, when I was washing it today I noticed that the rear discs are quite lipped.
The salesman told me when I bought it that there are minimum limits for things like brakes and tyres, but he didn't know what those limits were.
When I've had my car serviced at LR in the past I always get a detailed breakdown of the wear on tyres and brakes using a red amber and green system. But I got no such info with the car I've bought.
Does anyone know please whether I should have had anything to demonstrate that the 165 point check was completed?
Many thanks
Post #509119 18th Mar 2019 8:56pm
chugga90
The check sheet just gets ticked and filled with lies.
Ask the dealer to replace them and anything else they missed.
If they refuse, exercise your return within 30 days options and see if they see it your way.
Been bitten by LR before and never again.
Post #509125 18th Mar 2019 9:21pm
So
To be honest the dealership has been a bit tricky so far.
Does anyone here know what the maximum disc wear is on approved used LR?
Post #509139 18th Mar 2019 10:25pm
https://www.fullfatrr.com/forum/topic48225.html
Post #509140 18th Mar 2019 10:36pm
So
Unless I am missing something the minimum disc thickness is not in that thread.
There is a link to a document that I was given - i.e. what is checked on the 165 point check. But I wasn't given the form the tech in theory completed which will have shown the thicknesses.
Post #509142 18th Mar 2019 10:51pm
Quote:
122 Brake Rotor Thickness (rotors 50% of wear limit
Is about allI can see - what the wear limit is is anyones guess......
Post #509143 18th Mar 2019 10:59pm
andygts
Depending on which variant you have, new discs are either 20 or 25mm thick and both have a 3mm wear limit
https://webcat.firstline.co.uk/Home
You could always pop into one of the various highstreet autocentres that have got a 'free brake check' offer on, I'm pretty sure you'll get a piece of paper saying they need replacing plus a load of other things that don't. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #509148 19th Mar 2019 12:26am
Sizes/thickness's are stamped into your disc bells... Remaining thickness can then easily be measured Thumbs Up
Post #509151 19th Mar 2019 1:30am
Wrecker79
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Santorini Black
I too thought that the disc lipping on my 27,000 mile L405 was excessive, however in talking to two (admittedly L-R) garages before I bought the car (from another L-R garage) they told me that there was plenty of 'meat' left on the disc, and that a new disc only starts 2mm thicker than the minimum thickness (stamped around the hub area of the disc) and that this wear-rate would equate to 50,000 miles which is normal.
W. 2017 - L405 SC - WOW! just WOW!
2014 - L405 4.4
2010 - L322 3.6 - Carried me 100,581 miles then broke big-time
There are 10 types of people in this world;
Those that understand binary,
and those that don't.
Post #509418 21st Mar 2019 11:36am
