![]() | Home > Maintenance & Mods (L405) > How often do you change wiper blades? |
Quite often the blades and the glass itself needs a good clean Ryan... Depends what much gets on the screens & obviously this time of the year, they are needed a lot! |
Amazing Member Since: 17 Jun 2015 Location: China Posts: 61 ![]() |
I have only change once when they split but I kind of think the car wash place (which also had a new stock of wipers handy) split them as I had cleaned then a couple of days before and no splits.
And one other quick point, the rear tinted glass gets quite worn/scratched... This maybe helped by often changing wiper blades |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
Currently at 47,500 miles & 18 1/2 months old and there’s no sign of splitting and while you can tell that they aren’t brand new, they clear the entirely screen near perfectly. They look good for some while yet - maybe as much as another 12 months. As has been said, keeping the clean really helps; a gentle wipe with a sponge and some dilute car shampo, along their length, really seems to help. |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1424 ![]() ![]() ![]() |
Autoglym glass polish inside as well as out is helpful too, it makes a big difference, especially if the inside has not been done for a while. Only Range Rovers since 1988 |
I’ve never tried that, I’ll give it a go |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 436 ![]() ![]() ![]() |
Could depend on UV damage?
If you weren’t so foolhardy with your cash when you fuel up you’de be able to afford some new wiper blades sir ![]() ![]() ![]() ![]() ![]() ![]() |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
I normally replace ours at the end of every autumn. |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1041 ![]() ![]() |
Is this a trick question ??? 😂 |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
When they stop working properly |
V888CMW Member Since: 24 Mar 2019 Location: Sussex Posts: 3 ![]() ![]() ![]() |
75k miles in 37 months and still going strong on the RRS that is about to be returned for the new FFRR. |
