Home > Technical (L322) > Major Failure to Proceed... Help!
Page 2 of 4 <1234>
Gsxr1250dave
https://www.aulro.com/afvb/l322-range-rove...witch.html
Post #509179 19th Mar 2019 12:51pm
Shaun_
This forum really is fantastic! Thanks for the replies.
A couple more questions to help me rule things out...
Based on my symptoms
1. If the battery is starting to fail (it's about 12 months old) then would trying to start the car with jump leads from another vehicle help?
Paul - I appreciate your comments but the battery is spinning the starter with great vigour and no sign at all that it doesn't have the juice
2. Is there any way that I can determine whether it's the alternator?
Tugger...what makes them think that that's your problem?
Has anyone replaced an alternator on one of these - how difficult a job is it?
Thanks again
S 2012 TDV8 Westminster in the New Forest
Also: Land Rover Series 3 SWB, Mercedes 280SL, Classic Mini race replica, VW Golf SV
Previously: Audi A8, RR TDV8 Vogue, Audi Allroad, VW Golf GTI Edition 30, Audi A4 Avant, A8, A4 Sport, A6, VW Golf Mk5, Bora, Golf GTI Mk3, Jetta Mk3, Passat, Jetta Mk1, Golf Mk1
Post #509180 19th Mar 2019 12:58pm
Tugger
United Kingdom 2009 Range Rover Westminster TDV8 Stornoway Grey
I'm no expert but here's what happened to me
Driving along motorway this morning on way to work, slight incline and wanting to overtake, I gave it a bit more throttle, the gearbox kicked down and that's when the HDC alerts appeared, plus the other alerts previously mentioned by the OP
At that point I pulled onto the hard shoulder and the car just refused to fire, the starter was turning over but it wouldn't catch
Anyway when the recovery chap arrived (and what a top bloke he was too!) he was planning to drive it up onto his recovery truck but it still wouldn't start. He had a battery booster pack with him but even with that, it still wouldn't start. The fact that the lights and everything were working normally led him to think it was the alternator was, in his words, "gubbed"
So that's my symptoms, we'll find out in a day or so if it is the alternator once the garage has done their diagnostics. 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Nissan X Trail 1.6TDCi Tekna
Fiat 500 1.2
Post #509182 19th Mar 2019 1:06pm
Shaun_
Thanks, Tugger...those are exactly my symptoms (leaving out the earlier hesitant starting issue which I'm beginning to think may be unconnected).
Please let me know when you have yours back (which I hope is very soon) what the eventual outcome is.
I'd like to find a way of testing my alternator before either attempting to replace it myself or getting the car to my local indie.
Cheers 2012 TDV8 Westminster in the New Forest
Post #509184 19th Mar 2019 1:16pm
Fraynizzle
United Kingdom 2005 Range Rover Vogue Td6 Java Black
why would a failing alternator prevent the car from starting?
if the starter is spinning over correctly but not firing which i think OP said it is?
Sounds like it might be fuelling related to me.
Post #509197 19th Mar 2019 2:51pm
"spinning the starter"
and turning the engine over ? .
Post #509198 19th Mar 2019 2:56pm
Gsxr1250dave
I must agree with fray an alternator wont stop it from starting and if its spinning over battery must have a charge
Post #509199 19th Mar 2019 2:57pm
Shaun_
THIS is why I'm confused!!!
I don't understand why the alternator would prevent starting which is why I'm interested in the outcome of Tugger's issue and what makes a (presumably) quite knowledgeable recovery chap think of the alternator.
I agree it appears like a fuelling problem now, but if so then why did it all start with an HDC fault warning followed by every other warning message available(!) and still get me the mile or so home before then deciding it won't start? Those symptoms suggest to me an electrical issue.
I'll put the code reader on tonight but I fear there will be so many stored DTCs that I may end up even more baffled. 2012 TDV8 Westminster in the New Forest
Post #509200 19th Mar 2019 3:10pm
Tugger
As I sit here reading, I've remembered what may be a crucial point - the recovery man actually did get mine to start very briefly, it would only run for about 3 or 4 seconds and then die. It wouldn't even last long enough to drive itself onto the recovery truck. So I reckon battery and starter are OK - its just the minute the alternator is called up to spit out some juice, it fails.
Sorry if I led you down the wrong path a little bit - I'd genuinely convinced myself it totally failed to start at all.
Anyway, I'll make sure to get detailed feedback from garage and share it with you all as best I can. 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Fiat 500 1.2
Post #509204 19th Mar 2019 3:42pm
Shaun_
Thanks, Tugger. That makes your symptoms even more identical to mine!
Good luck, and please do keep us posted.
I hope for both our sakes it's something cheap and easy.
Oh, hang on... they're FFs!!! Laughing Laughing Laughing 2012 TDV8 Westminster in the New Forest
Post #509207 19th Mar 2019 3:50pm
Fraynizzle
exactly.
Shaun, is that what happens? key in position 3, the starter motor engages and turns the engine over rapidly like its trying to start but it just doesnt fire into life?
Post #509210 19th Mar 2019 4:14pm
Shaun_
Precisely 2012 TDV8 Westminster in the New Forest
Post #509212 19th Mar 2019 4:19pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
I know if the diode pack of the alternator is J. Arthured it can prevent the car starting as not enough power gets to the coil packs. It can also drain a previously charged battery a lot faster.
It could be worth getting some heavy jump leads on another big vehicle and trying that, wouldn't leave it running long though, alternators aren't as heavily over rated as they once were! Formerly happymadison1978
Post #509225 19th Mar 2019 6:34pm
Fraynizzle
Isn’t it a TDV8?
Post #509226 19th Mar 2019 6:40pm
Gsxr1250dave
You can disscconect the alternator on any motor it will still spin over and start if the battery is charged
Post #509229 19th Mar 2019 6:53pm
Page 2 of 4 <1234>
