![]() | Home > Technical (L322) > Flashing brake lights |
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 ![]() ![]() ![]() |
Normal if you've upgraded your lights, they do a check on start-up. You can turn it off with the IID tool. Assume it's that? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
I have the 2010+ rear lights, with all hot and cold monitoring turned off (no gizmo attached).
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
I’m not sure the hot or cold monitoring should cause the lights to flash, if they’re standard?
Bit weird if all standard, the monitoring does stop after a few flashes. I changed my reverse lights to LED bulbs and then had to turn the monitoring off using the IID. Worth a look either way |
