Home > Maintenance & Mods (L322) > Brakes not working correctly
nosmo
As above.
If I press on the brakes they work.
If I pump them a few times the pedal goes solid and brakes dont work.
I am hoping it is this break in the pipe that I understand goes to the servo.
The pipe easily slides off to reveal what I assumed was the nipple it should be attached to
On further inspection this pipe is loose and I can just remove it!
Looks like someone has done a bodge job on this before as its covered in some sort of gluey stuff
What part numbers should I be ordering for these 2 bits and will that alone solve my brake issue or could there be something else. 2003 4.4 V8 Vogue
Post #509571 22nd Mar 2019 5:40pm
ur20v
A Trap
Looks like someone stuck some copper brake pipe in with RVT or similar after the original broke. Don’t think you can get the fitting separately so you either buy a new intake pipe or re-hash a repair, just one that doesn’t leak!
Post #509580 22nd Mar 2019 7:07pm
