Home > Maintenance & Mods (L322) > New key experiment
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
New key experiment
So I purchased a replacement key of flea bay
The plan was to put my chip in the new key then try to program the my old key with the new chip
Didn't quite work out
Got the new key working but the chip swop went wrong the new key chip was glued in so it broke coming out
Next plan is to get another id46 chip and try to program my old key !
But the flea bay key is very well made it feels solid and weighty so I am pondering as to getting another new key and trying that route. The other problem is the transponders themselves yes you can get them but as yet not one that matches mine
Mines Pcf7936as. I can match this but the next 2 lines I can't
D8ye00039. As yet no similar match
Dn06370. No match
I wonder if my chip has been superseded by the ones on sale now . The experiment continues
Cost so far new key and cutting £47 , expected new cost - new chip ( if I can get it to program in ) £5 , or another key and cutting £47 so it could be either £52 for 1 old + 1 new or £94 for 2 new keys I'll keep this thread posted on my results success or failure.
So far I have a new key working and now a spare key with no chip better than only one key but not as good as 2 working keys Thumbs Up
Here's a couple of photos old and new
Old one
New one
Post #508788 15th Mar 2019 9:45am
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Good work there mate Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #508854 15th Mar 2019 6:29pm
Henda
I now need to source a good id 46 chip as I can't as yet program a key without one
Any ideas anyone
Post #509576 22nd Mar 2019 7:19pm
Ian Donkin
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
I went down a similar route with some nice looking keys off eBay that promised to work and I even paid a King's ransom to have my original transponder cloned onto one of the new keys. It worked once, but no more - I now understand that the original key has a rolling code in the transponder which these eBay keys / transponders are incapable of dealing with.
In the end I got a refund for both the keys and the programming work and ordered a genuine item from Dan at Duckworths. It came correctly cut and already coded for my vehicle - definitely worth the extra cost given the hassle I was otherwise having.
If you can get an original spec transponder (maybe even from an old L322 key) I'm sure you will have success, but the only firm that I found able to supply the correct item was trade only and wouldn't supply direct. 2011 Range Rover Vogue SE 4.4 TDv8
Post #509631 23rd Mar 2019 1:54pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Also gone down this route, Had the key cut & reprogrammed. Would unlock & lock, but would not start the car.
Removed the vehicles transponder to enable reprogramming, but still no luck, gave up in the end.
One thing that would annoy me if I had been successful, is that the key sits higher up than the original key & you catch it when changing gear. No problem if the ignition switch is higher up in the dash though.
Good luck Whistle
Post #509634 23rd Mar 2019 2:08pm
fenlander
England 2002 Range Rover SE 4.4 V8 Tonga Green
I just spotted the following link from Down Under which might be helpful to someone here
https://www.aulro.com/afvb/l322-range-rove...steps.html
Post #541037 18th Jan 2020 11:57pm
Henda
I just gave up and a got a Landrover replacement key not cheap but it works Thumbs Up
Post #541070 19th Jan 2020 4:47pm
pcourtney
gee whizz - I can see why after I read this on a forum down under
crazy or what !
Post #541102 19th Jan 2020 10:04pm
Henda
Yip you'll get headaches Thumbs Up
Post #541105 19th Jan 2020 10:26pm
BMG
United Kingdom 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
Odd. I made several new keys for my 2002 with an eBay AK90+ programmer and eBay keys and chips. Been in daily use for six months without problem.
https://www.fullfatrr.com/forum/topic51683.html
Post #541119 20th Jan 2020 12:18am
pcourtney
STELLAR - that is great news @BMG thx for sharing !
Post #541122 20th Jan 2020 12:39am
Henda
We are talking about the 07/09 variant which I think has rolling codes Thumbs Up
Post #541134 20th Jan 2020 7:56am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
07/09 completely different to 02/04 -- not able to programme it with the AK90+ -- you need CN3 chips Wink and a different box ! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #541152 20th Jan 2020 10:46am
pcourtney
lucky for us 2002 to 2005 BMW based Range Rover owners Smile
Post #541153 20th Jan 2020 11:04am
BMG
My mistake. Saw the 3 button key and assumed it was the BMW based system.
Post #541161 20th Jan 2020 11:50am
