Home > Maintenance & Mods (L322) > Easiest Oil change ever
bruno22rf
England 2004 Range Rover Vogue 4.4 V8 Java Black
Bought an oil pump from good old Lidl as I hoped it would perhaps mean that I could change my oil without crawling around on the wet drive - bit put off by the stated flow rate of .2 ltr/min for engine oil but hey presto - less than 10 minutes and 8 litres sucked from the sump - brilliant bit of kit for less than £15 with a 3 year warranty - so easy that I did my other car and my daughters as well!!
Post #509492 21st Mar 2019 9:22pm
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Seems a good thing but I would still loosen the sump plug and the secondary one if I ever find it and let it drain naturally without the dreaded mess Thumbs Up
Can someone tell me where the second plug is coz I can't find it Thumbs Up
Post #509494 21st Mar 2019 9:41pm
@Henda
See the wiki I posted images .
Post #509508 22nd Mar 2019 12:03am
Swipe
United Kingdom 2004 Range Rover Autobiography Td6 Java Black
I have used these on my previous 5 series so much easier than crawling on the ground. I have done a service on my Td6 as it was the first service I gave it since buying it I drained the oil from the sump plug, needless to say some ended up on my drive.
At least I know all the old crap oil was out, next service will be using the oil extraction pump no more mess or lying on my back under the car. Smile 2004 Autobiography TD6 Java Black
Post #509514 22nd Mar 2019 8:36am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
The sump plug only drains about a litre of oil on a 4.4 tdv8 ford engine the only way to drain the oil is sucking it out?
Post #509515 22nd Mar 2019 9:09am
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
I have been using an electric pump since the disaster on the driveway (oil everywhere)
However, once I pump the oil out, I still drain the sump.. I get about a litre and half out and that way all the dirt/sludge etc from the bottom of the pan comes out both front and rear sump.
Since I have blanked the egr, I expect the next oil change and the new oil to be cleaner for longer. Leaving any old oil behind (oil change with electric pump only) will contaminate the oil and the new oil will look black on day one. Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #509517 22nd Mar 2019 9:20am
Henda
Got that joe
Due a sevice shortly will see if I can find it Rolling with laughter
Cheers
Post #509518 22nd Mar 2019 9:27am
scotcruz
Easiest way is to use the spanner from behind i.e. under the bell housing.. once loose the oil drips through the holes on the small cross member type metal plate.. once drained.. I spray the break cleaner to make sure there is no oil left of the metal plate. Current:
Past:
Post #509520 22nd Mar 2019 9:36am
GI JIM
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Hi Bruno, are they back in store again now? May The FFoRRce Be With You
Post #509532 22nd Mar 2019 11:39am
bruno22rf
Came in about 2 weeks ago but my local still had several last weekend.
Post #509567 22nd Mar 2019 6:04pm
TJH1985
I use a pump as well, then drain the last little bit but to be honest it’s always only a dribble!
One of the best purchases I’ve made Cool
Post #509693 24th Mar 2019 4:15pm
