Home > Maintenance & Mods (L322) > squeaking creaking noise? |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1490 |
Close the window?
25th Mar 2019 5:24pm |
stucart Member Since: 03 Jul 2016 Location: Staffordshire Posts: 84 |
:DThanks for quick reply
25th Mar 2019 5:33pm |
Oh absolutely!
25th Mar 2019 5:54pm |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
On ours it was the rear hub upper and lower rose joints - easy job with the right tools |
25th Mar 2019 6:09pm |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 119 |
I had the old squeaky pram issue last summer. Would come and go depending on whether it was dry or damp weather and if I'd sprayed my rear bushes and rose joints. Convinced it was the bushes but my local indy identified it as the handbrake cable rubbing. Repositioned and insulated the cable and been squeak free ever since. Might be worth a check |
25th Mar 2019 8:25pm |
crowebeard Member Since: 19 Dec 2016 Location: Devon Posts: 93 |
I have the same problem nearside rear, although mine does it on bumps at slow speed as well. I had the top and bottom hub bushes replaced a couple of months ago to try and cure it, but it still squeaks.
25th Mar 2019 8:38pm |
Don’t think it’ll be handbrake cables as mines got the electric version, not been out since sprayed it so who knows , might try local Indy see if they can pinpoint it. |
25th Mar 2019 9:30pm |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 |
Stu, its the bush on the rear suspension.. easy way to diagnose is to pump some silicone grease through the rubber. Current:
27th Mar 2019 12:19am |
Any chance of a pic of which bush??? |
27th Mar 2019 2:32pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 785 |
Any one with this problem in the North West can have the bush replaced at my mates garage as they made the tool for the job and it took just 45 minutes a side to do mine....message for details. Best to get bush, washer, nut and concentric bolt of some one like Dan though as they are hard to source individually.... |
28th Mar 2019 11:01am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
Rear inner upper and lower wishbone bushes can also be a cause of squeaking .
28th Mar 2019 11:26am |
