![]() | Home > Technical (L322) > Uneven wear rear tyres |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1481 ![]() ![]() |
Find a good 4 wheel alignment specialist (with Hunter equipment) and get it checked and adjusted.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
Get a proper 4 wheel alignment done. It might be way out. Use a place that can put car into tight tolerance mode. If they don't know what that is then don’t use them. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
www.alignmycar.co.uk is a good start Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 712 ![]() ![]() ![]() |
Get it jacked up with the wheel off to check the suspension bushes.
Um, it is quite likely that both sets of rear suspension bushes (possibly including the toe arm) are shot and thus causing the wear (just as likely as the wheel alignment being out by the same amount on both sides) .
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 ![]() ![]() ![]() |
Thanks all,
Just a quick update to complete the thread, been into the mechanics today and both lower hub bushes/rose joints are knackered, and one control arm has seen better days. Booked in to do the lot and a 4 wheel alignment, £550.
PIMCO Member Since: 30 Jul 2018 Location: Oslo Posts: 44 ![]() ![]() |
So the lower balljoints were busted, but the uppers were fine? |
