Home > In Car Electronics (L322) > L322 2004 DSP disappeared FIXED
SilverParrot
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Had water ingress on my 2004 DSP. (Lear unit) Crying or Very sad
Cleaned up all the contacts etc on all plugs and sockets but no sound.
DSP is greyed out on the head unit, does this come back automatically if DSP is OK or does it need to be reset.[/b]
Post #509841 25th Mar 2019 9:42pm
MadL322
United Kingdom 2002 Range Rover HSE 4.4 V8 Cairns Blue
If the DSP has failed, have one for sale at the moment if you're in need
Post #509842 25th Mar 2019 10:10pm
SilverParrot
Will keep it in mind Thanks,
Am stripping everything else out tomorrow to check for other water damage.
Post #509844 25th Mar 2019 11:28pm
MadL322
if you need anything else, I have all the audio kit from the rear, took it out at the weekend in prep for a new head unit so all parts available.
Post #509846 25th Mar 2019 11:34pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Open up the DSP, mine had funk on the inside, and a disconnected pin! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #509864 26th Mar 2019 9:02am
mjdronfield
It will be grey in the menu until it identifies itself on the ibus, then it will be white again.
Should do this automatically, though might take a few minutes.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #509869 26th Mar 2019 10:12am
SilverParrot
Thanks mjdronfield Thumbs Up you pointed me in the right direction.
I have fixed the problem, it was a broken pin in one of the plugs, Ibus connection to DSP was lost, replaced pin, now all working again. Very Happy
Post #509911 26th Mar 2019 6:07pm
mjdronfield
Nice one.
Happy to have helped.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #509912 26th Mar 2019 6:09pm
