|  | Home > Technical (L322) > Diesel leak 3.6 tdv8 |
| Benner91 Member Since: 17 Oct 2015 Location: Belfast Posts: 87      | It’s the blue collar in the photo
|  27th Mar 2019 11:36am |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35878    | theres a workshop manual download link in the wiki that might help .. | ||
|  27th Mar 2019 1:01pm |
| Benner91 Member Since: 17 Oct 2015 Location: Belfast Posts: 87      | Has anyone any advise on removal of the injector shield I can see 7 bolts but don’t have any tool to remove the bottom bolts is there a flexible drive that could be recommended
|  27th Mar 2019 4:04pm |
| j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 389    | I used a load of wobble bars and flex head ratchet spanners. The ones by the fuel filter are a bitch. __
|  27th Mar 2019 5:03pm |
| Benner91 Member Since: 17 Oct 2015 Location: Belfast Posts: 87      | Thanks I’ll order some up
|  27th Mar 2019 5:08pm |
| Benner91 Member Since: 17 Oct 2015 Location: Belfast Posts: 87      | After removing shield 7 bolts hatefull job I found my diesel leak on injector return pipe I ordered a new o ring but when I went to replace o ring I noticed that the tip of return pipe on injector return 2nd cylinder on rhs was cracked and came off photo below
|  31st Mar 2019 6:45pm |
| j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 389    | Is that part of the stiff plastic pipe that fixes to each injector spill off port?
|  31st Mar 2019 8:21pm |
| Benner91 Member Since: 17 Oct 2015 Location: Belfast Posts: 87      | Hi it’s off the injector spill of unit that fits in to the injector secured by a spring pin
|  31st Mar 2019 9:01pm |
| j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 389    | Yes, you can replace the tee or corner piece if that’s what’s gone. But you’ll probably need to replace the pipe too as the stock rigid one will most likely crack. __
|  31st Mar 2019 9:15pm |
| Benner91 Member Since: 17 Oct 2015 Location: Belfast Posts: 87      | Thanks we’re can I purchase a t peace for my Range Rover
|  31st Mar 2019 9:20pm |
| j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 389    | I got some from a local injector specialist. I might have a spare, will check tomorrow __
|  31st Mar 2019 9:29pm |
| Benner91 Member Since: 17 Oct 2015 Location: Belfast Posts: 87      | Brilliant thanks | ||
|  1st Apr 2019 6:26am |
| j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 389    | Got one. Pm your address please. __
|  1st Apr 2019 6:40am |
| Benner91 Member Since: 17 Oct 2015 Location: Belfast Posts: 87      | Has anyone any tips on removing fuel lines from broken leak off injector nipple it’s very tight and I don’t want to damage pipe
|  1st Apr 2019 9:09am |
| Posting Rules
 as I can’t drive car now as diesel flying out
