![]() | Home > Technical (L322) > Slight Judder under braking, more so from higher speeds |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
A number of things to consider.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16366 ![]() ![]() ![]() |
As said above ^ |
Thanks Craig. |
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 832 ![]() ![]() ![]() |
Thank you Richard and Craig |
Take the car for the highest speed run you can and then simply put your hand on the rear wheels and if one is considerably hotter than the other then bingo! Thats the problem calliper... |
Will do - That's great, thank you Craig |
Check with the back of your hand not your fingertips from the rim inwards. (ask me how I know |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Use a leather gardening glove on first pass to avoid a burn Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 925 ![]() ![]() ![]() |
I am getting a similar juddering feeling through the steering wheel when pulling up to traffic lights pretty sharpish on the brakes fairly hard, I don't notice it at higher speeds, only when I am slowing down to a halt
Biffa4444 Member Since: 09 Jul 2019 Location: Ipswich Posts: 3 ![]() ![]() ![]() |
I've had the same problem, turned out to be a sticking caliper which caused the disc to heat up and warp. New discs, pads and calipers on the rear and its all good |
BenRK Member Since: 19 May 2020 Location: County Durham Posts: 164 ![]() ![]() |
Exact same problem for me. Gradually got worse until it was noticeable to everyone in the car when braking
