![]() | Home > Technical (L322) > Remove passenger side dash end piece to refit. |
Hi,
from what I can see in the manual:
Cheers! I'll have a poke about |
After some thought, the issue I had was with the lower part, not the part with the vent in it
Thanks - I'll give it a go this weekend. I'm still on cloud 9 after having my new tyres fitted and all the issues I thought might be drive-line/turbo/manifold warping going away |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
If you look into the vent you will see 4 spring clips - two on each side - they are the retaining clips for the vent. They need to be levered gently to allow the vent to be released. They have holes in them which lets you use something like fine screwdrivers to lever them. A bit of a fiddle to use 4 at the same time. |
Many thanks for all the advice guys - will let you know how successful I am! Land Rover Addict
Most excellent! Thank you |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
I would seriously suggest buying a trim tool kit and not use metal screwdriver as in that video!
I have plastic pry tools |
Well .... not being dexterous enough to hold four screwdrivers and also pull the vent out (the 2009 design in not the same as the BMW pre-2006MY version) - I reverted to that age old method of brute force. Grabbed the side of the trim and moved it towards where is should be, a bit of gentle force and clunk - it's back in position |
Ian Donkin Member Since: 17 Aug 2010 Location: A Yorkshireman in Surrey Posts: 107 ![]() ![]() |
Result! |
