Home > Maintenance & Mods (L322) > I hour fight with td6 injector no5
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I started having tick over issues after running the car hard so a bit of diagnostics, pulling the injector plugs off one by one pointed at no 5. As I had a used good spare in the toolbox today I made the swap. Ist thing I tried was to loosen the injector clamp and run the engine to pop it out. Not a chance, this one was not giving up so out with the eBay slide hammer. I hour of waking, loads of wd40. I finally got it moving. putting sideways / rotational pressure whilst using the slide hammer. Once out, what a mess, the hole was full of hard carbon. I used a shop vac with a 1/2 in tube to get it out. The washer was still in the bottom and that took another 1/2 hour to dislodge. Replacement in, all back together and a test drive confirms all is well again.
I would highly recommend the slide hammer tool, I would still be looking at it if I had not got one just in case.
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #510741 3rd Apr 2019 4:08am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Look at all that crud!
Out of interest is the EGR blanked?
Jim
Post #510745 3rd Apr 2019 8:26am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Looks like the copper sealing washer has failed hence the carbon up the side from combustion gases. It may have been suffering from lower compression on that cylinder and possibly a misfire if bad enough. The injector may actually be OK although if you had a good spare then it would be prudent to use it like you did.
More common on some engines than others with certain Mercedes being prone to it, google 'injector black death'.
I diagnosed a friends poor running TD5 with the same issue, luckily just needed new sealing washers. If not caught early enough on those then once the copper washer has given up it can then wear the head as well at which point no new washer will seal it.
Post #510754 3rd Apr 2019 9:46am
wayneg
Jim
The egr is blanked, I have done 55000klm in the car and did the blank as soon as I got it. The previous owner had work done on the head at a Dealers so they would have refitted that injector. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #510761 3rd Apr 2019 11:26am
