![]() | Home > Technical (L322) > Back from garage and worked for 1 day lol |
| dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724
In my 2011 , the FBH is much quieter than my 2007. Is there no heat in the interior ? 2015 4.4 AB
| dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529
When i got in the car it was blowing cold air Dolph.
| Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247
My FBH stays on when you unlock the car and get in. Used it yesterday morning and can distinctly recall feeling the warm air coming out the dash vents when I got in. Think it only goes off when you start the engine
My thoughts too,
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198
Moring Daz
Does the fbh exhaust get hot just from the engine running? Regards
Can't see why, it's not connected as far as I can tell.
Any reason having the bonnet open when turning the fbh on would make any difference???
Don't see why the bonnet being open would affect the FBH, but it is a FullFat |
Ok interesting discovery tonight today
Sounds a fair set of deductions.
With this lockout thing I don’t understand if it is locked out does this in turn mean that it won’t fire up with a cold engine and this help the diesel warm up faster to reduce wear??
If it enters error lockout, it needs the reset before it will run again.
Just looked agin at your post. You say 13 something on the run to Birmingham. That doesn't sound to good. Mine runs at least 14.5 at tickover once settled in, wiithout moving the car. You need to start looking into battery age, charging circuits and alterantor. charge the battery overnight and try in the morning.
| All times are GMT |
