Home > Maintenance & Mods (L322) > Anyone use the non detachable Westfalia tow ball?
Andy
If so, which holes are you using for the tow ball to bolt to for a level caravan?
 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #511001 5th Apr 2019 2:04pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Hi Andy,
Actually it's more detachable than the swan neck -- in that the pin holding the bar in only has a 'R' clip, the swan neck is nut and bolt and 'R' clip.
But to answer your question, exactly as your picture Smile
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #511003 5th Apr 2019 2:17pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Top hole works well for my box trailers and a 405 (that might make a difference).
If yours doesn’t have the anti rattle bolt fitted, be sure to sort out a receiver hitch anti-rattle clamp Thumbs Up
Post #511004 5th Apr 2019 2:20pm
Andy
Whats the anti rattle bolt then? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #511007 5th Apr 2019 2:50pm
Red Merle
The hitch itself slides into the receiver and is held in place by the pin. There is, however, a fair amount of free play that will rattle like a Censored with the trailer in place!
Some of them come with a hole on one side of the square section receiver tube, with a nut welded in place over the hole. You then screw a bolt through this nut, then through the hole, until it pins the hitch firmly in place, by pushing it hard up against one side of the receiver. If you haven’t bought it yet, make sure that the one you buy has this fitted (some do, some don’t).
If not, you’ll need to import an anti rattle clamp from the USA, where anyone who’s anyone has one of these receiver hitches fitted and knows exactly how to fix the problem Very Happy
https://www.amazon.com/Hitch-Clamp-Tighten...B0746QBCVT
Post #511010 5th Apr 2019 2:59pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Hi, Andy, the centre holes give you the same height as the swan neck type I have measured it and others can verify that on here?
Post #511012 5th Apr 2019 3:10pm
Andy
Thanks for all the replies.
On my previous TD6 I had a Westfalia detachable tow bar and that did rattle. I put up with that for 10 years not realising there was a fix! I did think about packing it out with shims at one point.
There is also a detachable tow ball on the TDV8 we’ve just bought but I’ve decided to remove the detachable bit and fit the one in my photo above. I’ve heard a couple of horror stories of them detaching so I thought I’d swap it. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #511013 5th Apr 2019 3:20pm
Red Merle
I’d agree with that plan entirely Thumbs Up
Post #511014 5th Apr 2019 3:23pm
The early versions of that tow hitch had a clean hole - so you could use a bolt or pin.
The later ones are half threaded, so need to be bolted and as a result of the thread, don’t rattle.
On my L322 it was top holes for an Ifor Williams.
https://www.fullfatrr.com/forum/topic44093...p;start=15
Post #511015 5th Apr 2019 3:27pm
Red Merle
I’m talking about a hole (with spot welded nut) in the receiver tube itself, rather than the solid metal bar.
Post #511016 5th Apr 2019 3:31pm
Understood - and needed with a smooth hole in the bar - but the threaded hole doesn’t need the additional anti-rattle
Depends which variant Andy has as that’s a library pic......
Post #511020 5th Apr 2019 3:47pm
Red Merle
Post #511021 5th Apr 2019 3:51pm
Andy
The TDV8 is sept 09 so I assume it was factory fitted. All the electrics are there dated 2009 as well. The detachable bit has never been used and is sat in the storage box in the boot.
Having said all that- the IID tool says towbar not fitted or something like that
I’ve just found this as well:
https://www.vehiclecoverscenter.org/softri...tener-for/ 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #511022 5th Apr 2019 3:53pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Amusingly this (not this particular one!) is normally on mine : https://www.vehiclecoverscenter.org/multi-...-chevygmc/ Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #511023 5th Apr 2019 4:01pm
Andy
Ok next question
My TD6 suspension used to lock when I plugged a trailer cable in. Do the later TDV8s do this? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #511073 5th Apr 2019 9:19pm
