Home > Technical (L322) > Does anyone know the flashing LED codes on IID BT?
Andy
My newly purchased IID tool is flashing 2x red and 4x green. It won’t connect to my phone. Patrick at GAP told me to tighten and clean the OBD pins which I have done. However it still won’t connect.
I’ve already sent one back that wouldn’t update. I’m getting a little fed up now.
The pins are tight as it’s now a bit of a push to get the tool in.
Asking today (Sunday) as GAP aren’t open till tomorrow and I need to clear a fault. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #511232 7th Apr 2019 4:30pm
Weegie
Try reloading the Gap ap. John
GAP iiD BT-Sold
Post #511237 7th Apr 2019 4:55pm
Andy
Can’t see what that will do as the tool is supposed to flash blue isn’t it? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #511239 7th Apr 2019 5:01pm
Weegie
True. It was just a thought that it might be something to do with pairing. John
GAP iiD BT-Sold
Post #511240 7th Apr 2019 5:04pm
Andy
If anyone is west Mids based could I try your BT tool in mine and vice versa? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #511242 7th Apr 2019 5:43pm
glenhendry
Australia 2005 Range Rover Vogue 4.4 V8 Java Black
If you can see the IIDTool on the RR dash, but not the phone, then you may need to crack open the IID box and reconnect the BT module PCB to the main powered PCB thusly:
Worked for me this week after much frustration.
Post #511624 10th Apr 2019 11:11pm
Andy
Mine has the digital dash so nothing appears on it. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #511644 11th Apr 2019 8:19am
