Home > Technical (L322) > Steering won’t lock
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Steering won’t lock
I recently had the “key won’t turn” issue and replaced the doughnut magnet in the steering column lock switch.
Although the magnet wasn’t broken, this fixed the issue.
However, after a couple of weeks of normal operation I’m now experiencing something a bit odd. When I insert the key in the ignition, there is no longer any “steering unlocking” noises, but I can still start her up as normal.
I don’t know whether to be nervous or not 😀
Does anyone have an idea of what’s happening?
I did recently change the battery in my key fob, but I can’t see that being related (the battery needed de soldering, so maybe I’ve overheated a chip or something) 2007 3.6 TDV8
Post #511207 7th Apr 2019 12:13pm
NobbyC
United Kingdom 2005 Range Rover Vogue 4.4 V8 Buckingham Blue
Are you getting any steering lock clicks when you switch the engine off and remove the key? No? Can you then still turn the steering wheel at all? Yes ? If so it sounds like the steering lock has stuck in the disengaged position and therefore not completing the locking immobilisation sequence. If you can read the codes this should show up as a steering lock failure. At least your still mobile at present - its worse if the lock fails closed as you wont be able to start or move the car but worth getting the codes checked as a first step.
Post #511256 7th Apr 2019 7:37pm
cheezels
Yep, that’s the symptoms.
I guess I need to pull the column out again 2007 3.6 TDV8
Post #511271 7th Apr 2019 10:35pm
NobbyC
Bit drastic. I think you can get to the mechanism with the column in place. Have a look at this which may help
Post #511369 8th Apr 2019 7:11pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
DANGEROUS bullshit video, never open the column!!! Meanwhile all officials send their column to my Workshop for repair the WHOLE column, this not for hobby mechanics, because the lock can snap on Highway.... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #511370 8th Apr 2019 7:26pm
