Home > Maintenance & Mods (L322) > 2008 TDV8 60k miles - should I delete EGRs?
WB
Hi, I've had my 2008 Vogue TDV8 for a couple of years and not had to do much to it apart from regular servicing and a couple of bushes and a whining idler pulley.
I've been reading about EGR and seen lots of threads on deleting or replacing them and was hoping for some advice on whether I should do this preventatively and if yes now or is it too early? Also is it better to delete or replace them?
The car does a few thousand miles a year and quite a lot of that is city driving.
Thanks for any advice
Post #511627 10th Apr 2019 11:44pm
DrRob
Do it. Use Bell Auto Services or one of their network. It will need an ECU patch as well as the blanking plates. Leave the pipes in place to keep MOT man happy.
I wish I could do my 4.4 but having a DPF it can't be done. Yet. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #511638 11th Apr 2019 7:35am
WB
Thanks DrRob.
Any suggestions for anywhere close to London that could do the job?
Post #511664 11th Apr 2019 10:08am
ur20v
A Trap
Why not fit a delete kit yourself? It’s easy and less than a hour with basic tools. Just buy a kit on eBay. No need to reprogram the ecu as no codes will show if you want to save money.
If you have a GAP iIB you can buy the patch and load yourself and do a tune if you so wish at the same time.
And yes you should do this or replace the original egrs before 80k miles when they seam to start failing and possibly destroy your turbos and engine.
Your choice on budget and fix and if you want to get your hands dirty.
Post #511672 11th Apr 2019 10:46am
WB
Thanks ur20v,
Will have a good look through the step by step I saw posted - I had thought it was quite a big job and also thought the ECU had to be done but if that’s not the case I should really put all those tools I keep buying to use!
Anyone bought this EGR kit? http://www.egr-delete.co.uk/product/range-...-3-6-tdv8/
Seems decent quality if they’re offering lifetime warranty.
Thanks again for the advice
Post #511708 11th Apr 2019 5:11pm
ur20v
A Trap
Yep that is the kit I purchased through eBay. Well made and fitted perfectly.
Post #511723 11th Apr 2019 7:07pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
WB, that is the kit I, and most others have used. It is well made.
I do recommend mapping out the egr's too. While active they can still break up, stick and cause codes and aggro. Also, the turbo's wont be getting the flow rates that Ecu thinks they are.
Whille you are at it, get the engine mapped too. You wont regret it. Mine is so quiet and pulls like a train.
£300 should cover the job which is half the cost of just buying new egr's. Then its about 6-7 hours labour to fit them.
So, £300 for a worry free fatty, or over £700 to keep the "green" brigade happy and crap fed back into your engine.
I believe the Yanks call it a " no brainer" 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #511726 11th Apr 2019 7:22pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
+1 for remapping a 3.6 , they fly after Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #511739 11th Apr 2019 9:31pm
Jon G
United Kingdom 2011 Range Rover Vogue 4.4 V8 Baltic Blue
+2 for the remap and the EGR delete Cool
Post #511826 12th Apr 2019 2:46pm
WB
Thanks for the advice.
I'll have a look into the remap too - any recommendations for anyone who can do it in or near London?
Post #511860 12th Apr 2019 6:41pm
Grofus
I know several guys with several different maps and they all work well. I used Quantum tuning and they have agents all over the UK.
Good map and reasonable price. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #511862 12th Apr 2019 6:51pm
gj88
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
When was your remap Grofus? I've been looking again for a while but struggling to break £400 in most places, including Quantum. At that price I'll probably still get round to it, it just shifts it down the list a little
Post #511869 12th Apr 2019 7:20pm
Save the planet Big Cry Wink .
Post #511870 12th Apr 2019 7:24pm
I’ve ordered the blanking kit so I can keep my bluefin remap Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #511890 12th Apr 2019 10:20pm
dolph34
+1 for quantum, i had/ have the blue map on both my 4.4 tdv8 and 3.6 tdv8. 3.6 is a quick job through the OBD port. Big difference in performance Thumbs Up speak to an agent as deals csn be done re the list price as agents are independent to a point. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #511892 12th Apr 2019 10:53pm
