Home > Maintenance & Mods (L322) > 2007 SC Brembo seal kit
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Can anyone confirm if this is the correct kit for the above car.
https://www.lrparts.net/seal-kit-for-bremb...sport.html
Thanks
Post #511735 11th Apr 2019 8:59pm
WB
That's the kit I used for mine which is a 2008 with 4 pot Brembos. One of my pistons had some corrosion on it so I also bought a piston kit and had those replaced. Don't have the details to hand but if you need them let me know and I'll look them up.
Post #511864 12th Apr 2019 6:54pm
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
You should probably replace the pistons while replacing the seals. The piston coating let's go and allows the aluminium to corrode. Ruins the seals and seizes the pistons. The ones from Zeckhousen Racing are not coated and should last longer. Stoptech 46mm pistons. 2007 L322 3.6 TDV8 Stornoway
Post #511867 12th Apr 2019 7:14pm
Full Fattie
Cheers. Just found them there, link for anyone searching for this in future
https://www.zeckhausen.com/catalog/product...s_id=12656
Post #511879 12th Apr 2019 8:28pm
S.Hafsmo
https://www.rangerovers.net/forum/6-range-...ics/232090 2007 L322 3.6 TDV8 Stornoway
Post #511920 13th Apr 2019 10:39am
Full Fattie
I’ve also found a company called Frentech in Burnley who offer a full rebuild kit for £89. 8 pistons and all boots and seals. Anyone used them?
There’s a separate company called SSL in Wakefield who will carry out the rebuild and paint the caliper for £245
Post #512021 14th Apr 2019 11:01am
WB
These are the pistons I used - Budweg pistons which I was advised are very high quality.
I had already bought the Brembo seal kit before buying this but the kit came with another set of seals.
https://www.ebay.co.uk/itm/RANGE-ROVER-inc...Swr5dbs2a8
Post #512088 14th Apr 2019 9:58pm
