Home > Technical (L322) > Engine oil service
gonfishen
Australia
Engine oil service
Hi all i am getting a message on start up service engine oil in 550km and that distance is counting down, The car was serviced about 3000km ago with new oil and filter , has the mechanic forgotten to reset the oil service count down ? We are proberly 1000km from the nearest large town and i hope the car does notgo into limp home mode, i can not get in contact with my mechanic till monday will it be ok to drive hope someone can shed some light on this many thanks
Post #511906 13th Apr 2019 7:22am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Most likely forgotten about by the mechanic although the interval is 'condition' based rather than a fixed value so it's dependent on a few factors.
Don't worry the oil service light has no effect on the running of the actual vehicle, it's just a reminder.
If you search online you'll find ways you can owner reset the light on your specific model.
Post #511913 13th Apr 2019 9:18am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
What year is your car and what engine?
Jim
Post #511914 13th Apr 2019 9:26am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
If you are that far from an LR garage Then I strongly advise you to buy and keep an IID tool in your car You can check lights and reset your own service lights, also why wait for a light to tell you when to do something? preventive work will keep your FF running much longer without letting you down or hurting your pocket?
Post #511915 13th Apr 2019 9:29am
gonfishen
Australia
No light just warning notice on start up , i got my mechanic to do a full check up ie pre travel check up because of the distances we were travelling
Post #511924 13th Apr 2019 11:03am
gonfishen
Australia
The car is an 06 RR L322 i spare no expence in service as i am not able to carry out servicing. It is a 3lt desial
Post #511925 13th Apr 2019 11:06am
