Home > In Car Electronics (L322) > Bovee 1000, what am i doing wrong
Steve67
Ive connected the bovee to my 2010 vogue , I’ve connected my iPhone 8 to the bovee but I’m getting connect divice message.
[/img]
Post #512014 14th Apr 2019 10:27am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Nothing as far as I can see, though as I'm not an apple user I wouldn't know, other than I've read some folk say you must have at least 1 track in iTunes.
Hope that helps Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #512015 14th Apr 2019 10:30am
Steve67
Hi, thanks. I have many iTune songs just doesn’t seem to connect. The phone mutes as if its playing through some source, but now I’m thinking the cable could be at fault.
Post #512018 14th Apr 2019 10:41am
Bushy30
Sounds like it could be the case, anyone around you with a working cable? Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #512024 14th Apr 2019 11:28am
Steve67
Ive tried the cable direct to my iPhone, and it works ok. Track listing and full function from the steering wheel. So now I’m stuck. Is there something else the tech people know I should try
Post #512026 14th Apr 2019 11:42am
Bushy30
Sounds like the bovee then, could you plug it and the cable into someone else's RR Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #512032 14th Apr 2019 12:16pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
You have to pair the phone with the bovee unit, into Bluetooth,you should see it mate
Post #512033 14th Apr 2019 12:18pm
supershuttle
Obviously you have to pair phone as others have suggested but as the Bovee doesn't recognise Spotify playlists (at least mine doesn't) I always have to set it playing on the Phone and then the Bovee just takes control Geoff
Post #512039 14th Apr 2019 12:33pm
ilard
Maybe it doesn’t like the music, please can you post a picture of you trying to play Spandau Ballet instead?
Post #512206 16th Apr 2019 6:13am
Steve67
Ha ha ha ha , thanks pal I’ll try some culture club. Can you recommend a good one from them. 😂😂
Post #512216 16th Apr 2019 8:26am
Andy
I’ve just fitted an Amazon Echo Input and I stream Spotify that way. I just tell Alexa to play a certain track or station. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #513331 26th Apr 2019 10:57pm
