Home > Technical (L322) > Adjust suspension height left and right sides with IID?
GGDR
Hi guys,
I can adjust individual suspension heights front and back, but wanting to do a gearbox service so ideally want to tweak the right side up a bit as I don't have 100% level surface .
I know the car self levels a bit but it's not sitting level enough for my liking. The spirit level bubble is way off to one side.
I've been into the two different kind of sub apps in the IID and can't see anything, have I missed something ?
Cheers,
Greg Cheers, Greg
Post #512029 14th Apr 2019 11:59am
Baltic Blue
Rolling with laughter simple solution , drive on two blocks of wood 👍👍
Post #512040 14th Apr 2019 12:36pm
GGDR
Yes Mike Evil or Very Mad that did strike me initially and will revert to couple of bits of wood if need be, only I thought there must be a tech solution!
. Cheers, Greg
Post #512041 14th Apr 2019 12:45pm
GGDR
Also kind bugging me the self levelling is not 100%, it's more in the ballpark levelling
. Cheers, Greg
Post #512042 14th Apr 2019 12:46pm
GGDR
...also a general expectation that you should be able to anything from your phone these days no? Order pizza, change the heating , jack up the car etc
. Cheers, Greg
Post #512047 14th Apr 2019 1:13pm
GGDR
Actually GAP website says:
Quote:
To manually control the air suspension, proceed with the following:
IIDTool Menu->Service Test->Suspension->Test Valve->Adjust Front, adjust to the desired height
IIDTool Menu->Service Test->Suspension->Test Valve->Adjust Rear, same as above
Each corner can be adjusted independently if needed
Will pop out to the car and have another go in a bit
. Cheers, Greg
Post #512049 14th Apr 2019 1:26pm
GGDR
Yep that worked:
It's pretty fiddly, a bit hit or miss but good enough to iron out the camber on the road.
No wood needed Mike!! Smile (although I had some ready)
Now, a pizza perhaps? Cheers, Greg
Post #512055 14th Apr 2019 2:32pm
Baltic Blue
I am very disappointed Greg, Rolling with laughter
Thought it was only old Luddites like me who still relied on a bubble spirit level Laughing
I could treat you to one of these, but you will probably find an App for you phone Rolling with laughter
Get with it 😁
Cheers Greg Thumbs Up G reg 2.5VM Vogue Portofino red 1991- 1999
Post #512058 14th Apr 2019 2:47pm
GGDR
Open your Compass app, swipe to the right - you have it already!
Comes with iOS!
But funny thing is, I don't trust it! And reach for old faithful yellow every time.
But you're no Luddite Mike, with your iPad on your dash especially! Thumbs Up Cheers, Greg
Post #512069 14th Apr 2019 6:22pm
