![]() | Home > Maintenance & Mods (L322) > Oil filter fitment |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
I have fitted 2 of these, and about to change again even though I have only done 3k miles since last change, but a lot of local short trips.
I also use the Mahle filters on my 3.6 TDV8
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
Weird that, just ordered a gen filter from Dan. Was a fomoco filter made by Mann. So it looks like Mann do 2 different filters for the car!! As it doesn’t look like the Mann Nino_nino has, Wells amen save for the cord round the outside. There is nothing that can't be fixed with a hammer😜😜
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
nmj can you put picture up, pls.
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1100 ![]() ![]() ![]() |
What I don't understand is this: -
dpm Member Since: 14 May 2018 Location: grimsby Posts: 48 ![]() ![]() ![]() |
I got the MANN filter yesterday came with a bag of 'O' rings but can't see where they all go, on the old filter which is same as new one even the filter casing hasen't got one on, are they not used ? |
You. need to fit the sealing ring as shown in green on the following...
OK thanks, I guess the other 'O' rings not used. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
I assume the filter pulled out and left the cage inside the casing ? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
That Mahle one has a raised area on the end compared to the Genuine one...?? For reference, scroll right down too see 3 different ones: Hengst, Genuine and Mahle https://www.advancedfactors.co.uk/service-...-168-c.asp Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Rob,
That would assist in either of them fitting perfectly then |
DrRob,
Nino
