![]() | Home > Maintenance & Mods (L322) > Do these prices look ok? |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Hi do you have a 6 or 8-speed gearbox if it`s the 8 then the price is ok, brake pipes mean that they will replace all of the brake fluid so not too bad, not sure about the gator but it`s a dismantling of the hub and everything attached to it so depends on labour gator is the cheap bit. Shocks? no that should be airbags which would make the car keep dropping down? |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Brake pipes i would leave to the expert. Flaring tools etc are needed. It does sound a bit pricey though.
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 175 ![]() ![]() ![]() |
Cheers guys, it did look a bit pricy to me.
Cant remember who does the flush on here. Maybe do a search. I think he is in the midlands somewhere. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1026 ![]() ![]() |
There taking the |
Check these price`s from Island 4x4 https://www.island-4x4.co.uk/suspension-pa...mp;sort=3a |
Looks like I need another quote/ vehicle checkup from another Indy.
RST Landrovers Ltd, 1-3 Kingsland Road, West Mersea, Essex, CO5 8RB or two in Kent |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
Bingo
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Chances are the front pipes are corroded, but original steel replacements are cheap as chips but not super easy to change. There is nothing that can't be fixed with a hammer😜😜
thanks guys, will be getting in touch with couple of other LR specialists to get the Driveshaft boot and Brake pipes done.
