Home > Technical (L405) > How do the "cooled" seats work ?
charlie croker mk2
How do the "cooled" seats work ? I have a late 2015 Autobiography which I purchased 2 years ago as a ex JLR management car when it was new to me the cooled seats provided a real cooling feeling but now you can feel the air flow but its hardly cool. Is the a separate air con unit in each seat or is the feed of air from the cars air con supply , can it be serviced or indeed does it need servicing ?
Post #512497 18th Apr 2019 10:50am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
They run separate from the main aircon . Iirc they run off something called a peltier heater that’s actually in the base of the seat, the L322 did anyway . Once Craig is on a tea break he may come along with his legendary knowledge Thumbs Up
I
Post #512499 18th Apr 2019 11:08am
Fifth Horseman
Very similar to the L322, description from Topix:
Quote:
A front seat climate assembly is incorporated within each front seat cushion and the backrest of the seat. The Seat Climate Control Module (SCCM) (Driver and Passenger side) and electrical wiring are located beneath each of the front seats.
The climate modules contains Thermal Electric Device (TED), which heat up or cool down depending on the voltage provided by the SCCM. Each climate module also contains a blower, which blows air over the TED to distribute the heated or cooled air through liners in the related seat cushion or seat backrest. The blower is also controlled by the SCCM.
Post #512501 18th Apr 2019 11:47am
I
Strictly coffee for me sir Thumbs Up Tea's drank by old people! Whistle Bow down Very Happy
Post #512554 19th Apr 2019 1:37am
fin
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
Tried mine for the first time yesterday, remarkably impressed, I did think they were going to be a bit lame.
Post #512733 21st Apr 2019 3:36pm
charlie croker mk2
Thanks for all the replies , Defo a coffee drinker LOL
Post #513131 25th Apr 2019 11:10am
brad s1
2004 Range Rover HSE 4.4 V8 Giverny Green
If they’re similar to the l322, they’ve got air filters that need to be swapped out regularly
Post #528031 15th Sep 2019 5:53am
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
never heard of these filters for the cooled seats. the book doesn't mention them. Any idea where they are so they can be checked?
Post #528050 15th Sep 2019 10:40am
Fifth Horseman
The filters were dropped for the L405
Post #528078 15th Sep 2019 2:52pm
brad s1
I looked up the part and the filter is still on there... Whether they give you access to it or not is another story but the peltier sort of needs an air filter.
Post #528092 15th Sep 2019 3:48pm
Just for technical clarity... I’m sat in a customers 14MY 405 and this has the filters present still sir... 👍
Post #528195 16th Sep 2019 11:37am
charlie croker mk2
Where are the filters situated and are they meant to changed or just cleaned as I can't find any reference to them on my "official" service checklist , Thanks
Post #528220 16th Sep 2019 1:44pm
brad s1
There are two units in each seat, one in the seat back and one in the cushion. Yes the filters need to be changed out and this could very well be your issue. If your seat heating still works then the system likely isn't broken. The heating action relies on all aspects of the system working as it should, cooling the system can be damaged/faulted and still function. The peltier cell is the thing that provides the heating and cooling. When on one side of the peltier cell heats, the other side cools. When heating it moves air around closed loop in once direction through the system on one side of the cell to warm. When cool it is open loop drawing air over the cold side of the cell in another direction and out the perforated area of the seats. If the filters are clogged it won't be moving very much air over the cell which results in diminished cooling. When cooling it should be roughly 8 degrees F below the ambient.
I have not looked at my l405 yet, but on my l322 the filters were on the front outside edge of the seats on the bottom. It is a round fabric filled thing, clearly looks like a filter. You turn it and it pops off. You can get replacements on amazon/ebay for a couple bucks each. The seatback unit however is much more difficult to reach. The seat back has to be removed in order to access it though IMO since it's located within the seat itself, this filter rarely clogs with particulate. In my experience the filter material even though possibly not clogged up with particulate becomes ridged over time and inhibits air flow so it is a good idea to replace them.
The other issue is the unit itself over time is prone to physically cracking, depending on where it fails you may loose the heating/cooling function... tho as previously stated, if your heating still works well most likely the system is okay.
Post #528235 16th Sep 2019 3:01pm
brad s1
Also possibly helpful to mention, if you have a capable diagnostic you can actually monitor how the cells are performing, there are several temp sensors throughout the system... If you live stream the temp sensors on the particular seat WITHOUT it running. All the temp sensors should read roughly ambient. If there is one temp sensor displaying some improbable temp the whole blower unit/peltier needs to be replaced. That or maybe the seat itself throws a code and disables itself (but not always) with no diagnostic if the heating works, you're likely in good shape. When heating the system makes use of all its temp sensors in an attempt to not set fire to the car Smile
Post #528236 16th Sep 2019 3:11pm
charlie croker mk2
Brad S1 : Thanks for all that , Getting the Autel out tomorrow when I get home .
Post #528247 16th Sep 2019 4:41pm
