![]() | Home > Technical (L322) > First time off road - suspension fault |
| Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577
Detached suspension sensor arm or air leak for visual and aural checks. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
| AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464
My leak was only audible when I set the suspension to off road (high), it was then clear to hear.
| gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158
Most likely what's happened is the bag has split as it folds in on itself at normal and low height and wears over time. When you go into extended mode this part of the bag is stretched and exposed and eventually might fail with a loud bang like mine or just leak. Bags are easy to replace on the front with the right tools.
| All times are GMT |
