![]() | Home > Maintenance & Mods (L322) > Battery drain - unexplained! |
My 2009 Westminster has an odd habbit. The battery goes flat but *ONLY* when it is at race circuits. So far Donington managed to flatten it so much that the key wouldn't even turn, and Snetterton lit up the dash with errors and the engine turned once. I thought they had sorted transponder issues out on these vehicles?
do you leave the doors/tailgate open with the interior lights on?
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
And replace all the interior light bulbs for LED’s, if any stay on there’s a lot less current draw |
i think if you switch the AC off a couple of times it will 'learn' that setting... |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 175 ![]() ![]() ![]() |
cheers Stan, will try that. thanks |
Nope, vehicle is parked up for 3-4 hours with the boot being opened a few times to offload gear at lunch time. This is most baffling. It sits at work for 9 hours and doesn't have this problem.... It is specifically at race tracks.... (although it didn't happen at Brands Hatch 2 weeks ago) Land Rover Addict
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
It MAY be something to do with the radio frequencies being used at the tracks and the transmissions are triggering something in the ECUs which is activating some of the systems, which are in turn draining the battery.
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 543 ![]() ![]() ![]() |
If you measured the current drain at home and then compared with the same at a circuit, it would start to narrow things down.
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1527 ![]() ![]() |
Does it have an FBH? Wonder if that's being triggered by telelmetry comms? Formerly happymadison1978 |
It does have an FBH..... Hmmnmm. Obviously at the weekend it would have blown cold as it was more that 16 degrees outside. I may have to stick a recording device in it.... Land Rover Addict
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 ![]() ![]() |
Obviously EMC approvals is not on most car manufacturers to do list, this has to be a RF problem. I'd start by looking at all receivers and subsequent ecu activity. Bloody nightmare battery drain on these FFRR and it only happens when you least need it! In the winter I do not leave the FF idle for very long! |
Cheers - I've just been told by another photographer that 2 D3's did the same as mine parked in the same area. So seems it is a Land Rover thing!!! Land Rover Addict
It did it again at Croft Circuit .... asked nicely for help and within a few minutes we had a generator and truck battery charger hooked up.
