Home > Technical (L322) > Heated and cooled seat help |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1133 |
Have you taken the unit out yet? you could try BB Reman they take all sorts of stuff apart and fix.
26th Mar 2019 1:47pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1194 |
There's a lot of info on here if you search for this. Try peltier, heated seats, cooled seat etc.
26th Mar 2019 2:27pm |
Landyandy1765 Member Since: 25 Mar 2019 Location: bournemouth Posts: 56 |
Hi I've had the seat apart and found the cracked duct . All the controls work and the seat I've got issues with starts up with the fan running then after 30 ISH seconds it cuts out . |
26th Mar 2019 3:44pm |
That was the same as most people on here its the crack in the ducting that stops it working as said before plenty of info on the search? I`m afraid it`s hand in the pocket again. |
26th Mar 2019 4:56pm |
Baben's post in this thread may help:
26th Mar 2019 6:33pm |
I know you can pick up pelitors for next to nothing so I'm determined to buy the correct one to replace the broken one I have .
26th Mar 2019 7:16pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
I've tried and failed:
26th Mar 2019 8:56pm |
I know a very clever guy who is itching to sort I out . Will keep you posted . |
26th Mar 2019 9:12pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 837 |
Arrrrhhhh 1st world problems 😂 |
26th Mar 2019 10:02pm |
Any luck with your friend Landyandy?
22nd Apr 2019 12:32pm |
In the last two weeks I've received the peliter so will keep you updated . I will take loads of pics to show the start to finish progress.
22nd Apr 2019 2:41pm |
Nice one Andy.
22nd Apr 2019 7:20pm |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
Watching this topic with baited breath and crossed fingers. Can’t quite stomach the cost of a new unit, but having switched the working unit from passenger to driver’s seat, I do hear quite a lot of moaning! Have kept the old unit in hope of a repair... Current: 2010 Range Rover L322
23rd Apr 2019 8:58pm |
gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158 |
The bf went to the effort of removing mine only to find all the ducting etc was in place. The IID tool also showed a fault
25th Apr 2019 5:43pm |
