| The rust might be from the shields around the brakes, which are well known for rusting.  They can rust through at the mounts and need first repair where oversized washers are used to secure them (they are a faff to remove and replace, the washer approach is much cheaper) and then maybe replacement.  There are threads on here about that.  There will be rusting also in the ventilation channels between the outer faces of the front discs, normally not bad enough for the discs to fail, my winter wheels came off the car this spring with significant rust staining, dealer checked discs and said there was no problem with structural integrity.
 In my experience callipers tend to seize internally before any external corrosion affects their functionality, rears tend to go before fronts as they get less use.  I've only ever used LR genuine brake components and believe that to be the best policy.  If you are getting a judder then maybe they are starting to stick, they can be freed off (my 322s tended to need that at the rear every year) but if too far gone need to be replaced.  Sorry no view on cost as too long ago that I had that done.  No view on conversion, but the later 4.4 TDV8 type callipers at the front would need style 15 wheels or 20s to clear them, Q if worth the extra cost.  The judder could alternatively be from worn steering components, worth having that checked as well as the brakes.
 Incidentally I think harsh wheel cleaners don't do the brakes any favours and now just wash with cold water and a sponge and brush, and then a polish when the wheels are off the car for summer/winter as the case may be.  LR recommend taking the car for a drive to dry the brakes off after washing, and I always do that. Only Range Rovers since 1988
