Home > Technical (L322) > Ggrrrrr more problems bit of help please
andyfid
England 2003 Range Rover Vogue SE Td6 Tangiers Orange
Right where to start let’s go for the rear blowers not working checked the little black bar and that is still on checked fuses and all ok so would I be right in saying the motor is kaput?
Other thing is the fuel burning heater I had sent the board off and done by mike and also had the lcm repaired and the bm54 done and ever since the aux heater setting on the screen is unavailable to turn on as it’s not highlighted only the direct settings can be set but nothing is happening the orange light just flashes I know now the weather has picked up but I just want to get it working ready for winter I was testing it when it was cold and the outside temp was 3 degrees,could it just want redoing on the computer by someone?? Any help would be great
Post #513604 29th Apr 2019 8:56pm
andyfid
Also when the fuel is at 1/4 is a pain to start
Post #513606 29th Apr 2019 9:02pm
You might need a diagnostic tool, e.g. IIDTool, to turn the Aux Heater function back on ?
Fuel at 1/4 full
In tank fuel pump - search the forum, lots on this
for example:
https://www.fullfatrr.com/forum/topic39866.html .
Post #513619 29th Apr 2019 11:27pm
andyfid
Cheers joe any good with radios as mine keeps turning off or freezing checked all connections in back left and they are good as I sorted the boot seal last year and most of the boxes and amp have been done but it keeps doing it even tried unplugging the day nav and still the same 🤯🤔🤔
Post #513625 30th Apr 2019 3:47am
