Home > In Car Electronics (L322) > 2004 Vogue DSP missing quite literally!!
Page 2 of 3 <123>
broncoupe
It looks like the original block is still there
I had a similar car to sort I just rejoined the wires colour too colour
got a unit off flea bay all done paid around £120 for it
audio back DSP on screen again but sound quality is very low rent
Didn't need coding not in my case yours shouldn't either
Post #513628 30th Apr 2019 7:58am
MONT322
England 2004 Range Rover Vogue 4.4 V8 Cairns Blue
Many thanks for the words of encouragement Bron Thumbs Up I'm hoping its going to be that easy to sort.
Just got to get a DSP that is working then I'll get cracking with the soldering iron.
I'm not too worried about the quality - all I want is to get it back to original with some audio at least so I can play my tapes Laughing
Post #513636 30th Apr 2019 9:40am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Have you been recording the charts show again Rolling with laughter Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #513637 30th Apr 2019 9:53am
MONT322
Yes Bushy.... Got all my old cassettes from Ourprice and Woolworths to play mate!! Rolling with laughter
Post #513650 30th Apr 2019 10:15am
Weegie
Would that be 8-track then? Rolling with laughter John
GAP iiD BT-Sold
Post #513660 30th Apr 2019 10:53am
broncoupe
You’ll be fine
You can check individual speakers with a 9 volt battery
Just listen for the click
The only caution is on power and ground connections
If for any reason a speaker is wired back to front it will still work
Just be out of phase
Post #513680 30th Apr 2019 12:57pm
MONT322
Thanks again Bron - much appreciated!
Post #513681 30th Apr 2019 1:24pm
MONT322
Hello me again!
So after spending a few hours earlier putting the wires back colour to colour and removing all the foreign objects ready for the arrival my DSP I have a couple of extra issues!?
On the drive home I noticed air suspension inactive on the dash (no bong to tell me tho) but all was working fine?
I raised it to max height but I didn't get the bong that tells me that it doesn't like going over 30mph in max that I usually get?
Lights on the suspension all there and working as it was flashing and lowering to normal ride height - tried it a couple of times no change?
The other issue - indicators not behaving? No clicking noise or lights every now and then on the dash when engaged?
If I flick the stalk it takes a few seconds for it to work when it should be instant? On cancelling the the indicator it carries on for a few more blinks?
very weird goings on?
Post #513912 1st May 2019 9:39pm
MONT322
I'm hoping that by letting it rest overnight it will sort itself out!??
Post #513913 1st May 2019 9:45pm
Bushy30
Air suspension could be a weak pump, simple fix with repair kit.
Really though, you need a fault code reader.
If you're getting weird stuff, have you checked the battery? Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #513921 1st May 2019 11:12pm
MONT322
Cheers Bushy but I reckon its something that I unplugged and plugged back in yesterday that looked abit oxidised - the big plug on the bm54.
It's got to be something I did yesterday as I've never had these issues before?
Fingers crossed its reset itself overnight?!
Post #513930 2nd May 2019 7:04am
Bushy30
Corrosion in the plugs and units could be the key Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #513933 2nd May 2019 7:59am
MONT322
So on the drive to take my boy to the childminders this morning the other issues have seemed to disappeared?
No inactive suspension or crazy mind of there own indicators? I think just leaving it overnight has reset itself - hopefully!!
BUT i have a little secret that i've been keeping from you all - I'm getting the blank screen on the dash and have had this since the beginning.
After a closer look at the other connectors look what I discovered.....
Broken pins too!!
Look at the state of this!!
Gotta love it!! Big Cry
Looks like I need to get back on the bay for one of these ASAP!!
Post #513943 2nd May 2019 9:54am
MONT322
Does anyone know if a replacement YIL000023 would plug in and play like the DSP?
Post #513953 2nd May 2019 10:09am
Bushy30
Yes, should be, though you could probably clean and re-solder that one -- you may need to get in the unit too though Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #513954 2nd May 2019 10:11am
Page 2 of 3 <123>
