Home > Maintenance & Mods (L322) > New owner...folding mirror problem.
andyshad
England 2003 Range Rover Vogue Td6 Zermatt Silver
Hi all...just got my first TD6. Had Disco's 1 and 2 ( still got the D2)
2003 with 76 k on it. No sat nav.
Love it so far.
My mirrors fold in and then straight back out, This car'nt be normal. Is there a fix.
Also, no phone kit installed, so whats the best option and could some kind soul point me to a link.
As i'm still waiting for my owners manual, is there a link to what all the switches do . Sussed most of them
but not 100 percent.
Thanks in advance.
Post #372382 14th Feb 2016 8:33pm
Dolphinboy
Welcome Andy (hey my first newbie greeting!)
Do a search there is plenty of info on here how to but to my best recollection it involves double-tapping the mirror button (best make sure u don't have a 9mm in your hand at the same time - could be expensive! Whistle
Post #372385 14th Feb 2016 8:40pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Welcome Andy.
If Dolphinboys suggestion does not work, there is a little metal clip which can work loose and may well be worth taking the shroud off for a look. simply reclipping the tag back in worked for me. Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #372386 14th Feb 2016 8:45pm
andyshad
Thanks dolpinboy..
Ajac8, is the clip in the mirror. By shroud, do you mean the back of the mirror.
Cheers guys
Post #372387 14th Feb 2016 8:59pm
ajac8
Hi, it been a long time since I had to do it but yes i remember taking the shroud off (the bit you would normally colour code). As the mirror closes there is a contact made with the clip i'm talking about. this comes loose and simply needs refixing in place. It worked for me but my memory is sketchy. hopefully someone here will know what I'm trying to explain.
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #372393 14th Feb 2016 9:27pm
The manuals and hand books are in the WIKI, top right of screen under fullfatrr.com...
Get one of these for the hands free... Thumbs Up
http://www.fullfatrr.com/forum/topic27033.html
Fitting thread
http://www.fullfatrr.com/forum/topic29219.html Pete
-Click here for Thread-
Post #372401 14th Feb 2016 10:08pm
espaceboy
first try a mirror reset. push the fold button down twice in quick succession.this may fix it
if not its the micro switch in the mirrors. the metal clip is actual the micro switch arm that falls of the switch. re-attaching often cures the problem,
you will have to look at both mirrors to check
you don't need to remove the whole assembly from the door, but you do need to remover the outer mirror covers. this is achieved by using a thin scrapper or steel ruler and sliding it around the gap in the mirror to remove the glass frame. once down the cover can be removed
the micro switch is hidden under a cover which slides towards you.
or you can look in the wiki
http://www.fullfatrr.com/gallery/thumbnails.php?album=341 Thumbs Up
Post #372413 14th Feb 2016 11:07pm
p38arover
Australia
I shall have to try the reset. In hot weather (most of the time here), the RH mirror folds in then back out. The LH mirror stays closed. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #505534 18th Feb 2019 8:01am
sibelius
Finally!! The reset didnt fix it, so I took the mirror cover off, found the plastic cover that fits over the micro switch. when I removed it the small metal arm that operates the switch had dropped off, fitted it back on and sure enough the mirror now folds in and stays folded. Thanks guys.
Post #513670 30th Apr 2019 12:09pm
MONT322
England 2004 Range Rover Vogue 4.4 V8 Cairns Blue
good skills Thumbs Up
Post #513673 30th Apr 2019 12:30pm
sibelius
we should perhaps step back and take a long look at ourselves!! We no longer want to fold a mirror back ourselves, nor do we want to adjust it ourselves, let alone adust the drivers seat position!!
However, the problem has gone away and without parting with any cash!!!!!
Post #513676 30th Apr 2019 12:36pm
