Home > Maintenance & Mods (L322) > Coding auto unlock on an 05?
Danwilderspin
Hi all I want to code lock when driving and auto unlock in park. I know allcomms can do this for the bmw gear but will it do it on an 05 s/c? I am not sure if this is one of the legacy systems they was carried over for a bit? Cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #513678 30th Apr 2019 12:44pm
no auto un-lock available on yours..
Post #513697 30th Apr 2019 2:48pm
Danwilderspin
Cheers Stan - does it use ibus partially still (for the clock maybe?) on this year? As I currently have an intravenous to do the locks.. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #513707 30th Apr 2019 3:18pm
sorry no idea..
Post #513709 30th Apr 2019 3:22pm
Danwilderspin
Laughing no worries there is a reason I’m asking I want to fit the deployable steps as I believe they have the newer air cylinder and can system to take it but they only work off the locks? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #513711 30th Apr 2019 3:33pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
What are you trying to work out with steps Dan? Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #513713 30th Apr 2019 3:37pm
Danwilderspin
So i bought a set of the steps from Dan for my 4.4 Bmw engines l322 and I managed to sort the wiring out however they only deployed when the locks were up and retracted when down. To make this happen in a more automatic way I put an intravenous in which sits on the ibus and does loads of cool stuff like custom welcome lights, triple turn signals and for me unlock in park and auto lock when driving. I set all this up fine with help from Matt as it needed a translation module for the can bus for the passenger step but the air cylinder was in the way for the driver and didn’t like the idea of botching a bracket on so they have sat in the shed collecting dust. Fast forward to a 05 supercharged and it now has the correct wiring although not pnp as it’s in the wrong place prior to the internal facelift, and I’ve been told the air tank is changed on the 05 (can anyone confirm) I pick it up on Saturday or I would myself.
Anyway I was trying to work out how they can be as automated as possible and assumed they’d still rely on the doors unlocking so was trying to figure out if this could be coded or if I could put my intravee on if it still uses some Bmw systems like maybe the body module?
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #513716 30th Apr 2019 4:00pm
Bushy30
They're pretty much automated as standard.
Open on unlock, stow on door close.
Open and close on door open and close etc
No need for any poking, they just do it ! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #513718 30th Apr 2019 4:05pm
