![]() | Home > Technical (L322) > High Level Brake Light |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2075 ![]() ![]() ![]() |
Just been told mine is not working.
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
How did you sort this in the end? I note mine is not working at all either. In fact, it may not have worked since I got the car in November last.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Not sure what help I can be but the spoiler is removed by opening the top hatch and undoing the 3 nuts at the base of the hatch by the hinges. Thing their 10mm. Shut the hatch and stand on the lower and pull the spoiler towards you. Then lift up. Becarefull as the rear light cable is only short. That will give you access to the rear light. The wording comes from inside so you willneed to remove the top upper trim peice. That just pulls off straight. Search my old posts as I posted a few pics from the weekend when I fixed my rear washer/wiper. Put a few pics up that may help. |
Thanks oodathort. Is this another of the common faults do you think? I know its only a £65 part from LR, it just ticks me off when I think the car cost its original owner 68k 7yrs and 4 months ago. I have just replaced the heater hedgehog then the rear wiper motor that had turned to rusty mush inside due to another common fault. Sorry, whining now, I will go for a quick blast and forget its little foibles!! :)Further thought -I think Dan made this point once over-the bits just mentioned are all BM sourced ! |
No I didn't sorry, not looked at it TBH
Getting to the light unit is straight forward. Working at the top edge of the tailgate inside, remove the three 10mm hexhead bolts securing the spoiler, and disconnect the two-wire multiplug from the loom. Release the wiring clips. Working outside, slide the spoiler rearwards and off its mountings. Pull the cable grommet out of the hole in the roof, release the cable carefully and then remove the spoiler off the roof.
