Home > Maintenance & Mods (L322) > Rear tow hook
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Rear tow hook
Do all 2012 L322s have rear tow hooks fitted as standard?
Mind does not have one.
Thanks 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #513588 29th Apr 2019 7:33pm
bishbosh10
I think you answered your own question!
The answer is no. Smile Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #513590 29th Apr 2019 7:43pm
rjff
^1
but you may well have tow preparation fitted. Mine had no bar but was fitted with a connector in the spare wheel well, rear bulkhehad, left hand side, looking from the rear of the car. It's a grey rectangular socket.
You may be able to get a build sheet form Topix or you may be able to search with your VIN number on vindecoderz.com. It can sometimes work, or not, keep trying.
Then it's a case of the towbar choice. Cheers
Richard
Gap IIDBT
Post #514009 2nd May 2019 5:36pm
DrRob
As above, a 2012 should have the towing loom and box in the boot ready to plug a towing electrics kit into.
Grey box on rear edge of wheel well
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #514042 2nd May 2019 9:56pm
TDV8_Tommy
Thanks, guys.
The car did previously have a tow bar, but removed before I took ownership. This explains it. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #514096 3rd May 2019 1:07pm
WdeRave
Spain 2010 Range Rover Vogue TDV8 Santorini Black
If needed I have the "side tow bar parts" available for a 2010/2012 model.
Just installed a new removable tow bar (a non Land Rover), that came as a complete set.
Also found a 13 pin cable with the correct connector to make use of the available connector in the boot.
Worked straight away!
 RR Vogue, 4.4 TDV8, 10/2010, Santorini Black
(EGR out, 380HP, 800Nm)
Post #514098 3rd May 2019 1:47pm
Andy
I’d be interested in the 13 pin connector with loom if no-one else has first soviet on it. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #514356 5th May 2019 12:44pm
WdeRave
Hi Andy,
I only have the side brackets available.
Purchased a new tow bar and cable for own use.
Found in in The Netherlands at (sorry for the Dutch language website):
http://ecs-trekhaakbekabeling.nl/landrover...over.-13p/
This is a 13pin cable with the correct connector. Installing was just 30min work! Thumbs Up
The manual is on this pages, so take a look and you know Very Happy
The part number is LR-017-DH (or LR017DH), so maybe you can look if you can find it in the UK too.
Success. RR Vogue, 4.4 TDV8, 10/2010, Santorini Black
Post #514370 5th May 2019 2:44pm
