Home > Off Topic > Shed roof felt ?
GGDR
Shed roof felt ?
hi team,
An un-wheeled topic, I have a small shed 1.5x1.5 metres and the roof felt is failing in places.
Firstly, as far as felt goes, if I re-felt it'll have an annoying join (weak point in my book). Not such a problem, all sheds have overlapping joins, more annoying at my shed size that there are no rolls available wider than 1m.
Or I can paint over it with something like Everbuild Blackjack.
https://www.everbuild.co.uk/wp-content/upl...G-V1.1.pdf
So should I re-felt, or paint 'magic' stuff on top?
Cheers,
Greg Cheers, Greg
Post #514202 4th May 2019 12:04pm
Looking for a temporary bodge or fix it permanently ?
I've just built a porch type thing & used EPDM which seems remarkably good - basically inner tube material glued to the roof - they reckon good for 50 years Shocked
Comes in big sheets - so you order the size you need - no joins
Roof is OSB - then a contact adhesive, then the EPDM on top - finish around the edges as you see fit Thumbs Up
I got mine from this place & they also do shed kits - https://www.rubber4roofs.co.uk/shop/epdm-shed-rubber-roof-kits
Post #514211 4th May 2019 12:56pm
GGDR
Thanks Alistair!
Like that!
(I want something lasting)
. Cheers, Greg
Post #514281 4th May 2019 8:25pm
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
just bought a 2.5m x 1.2m piece of EPDM, and adhesive and a roller for £36 delivered from eBay
Post #514289 4th May 2019 9:07pm
