![]() | Home > Technical (L322) > Front end droning noise |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 ![]() ![]() ![]() |
Oh I should add the car passed its, mot recently with no issues, noted. So.....? 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Likely a wheel bearing 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 ![]() ![]() ![]() |
I've got a droning noise that gets louder the faster I go...... It's called a wife !!
A droning noise... that cooks ya tea! Interesting.... |
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 ![]() ![]() ![]() |
Sounds like a wheel bearing to me. Current: FF Westminster money pit
Thanks, Do I buy a new wheel bearing off ebay for £40-50 that I assume will require pressing in after |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 ![]() ![]() ![]() |
Out of interest, and sorry to hijack the thread. If I’m driving and put it into neutral can I just put it back into drive while I’m still going? Or do I need to stop the car first? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
Yes. Why do you want to?
I'm praying it isn't one of the diffs!! I drained and refilled em and transfer box with correct oil though about 6mths ago... |
I had a similar thing on an old car and it turned out to be the engine tray being loose. The remaining clips kept it in place until I got to about 60 then it would fold down and make a constant buffering sound and feel.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I have a strange noise as well. It makes a dull thump thump noise when I pull away and speeds up the faster I go. The frequency between thumps is consistent with the outside diameter of the tyre hitting the road surface. In other words it’s not a fast thump which would come from a rapidly spinning driveshaft or bearing/hub. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
Andy I think you'll find your driveshafts and hub bearings turn at the same rate as your tyres/wheels? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
Yes I know that!
IF as in my case the drones tone varies according to road speed and worsens/gets louder when the steering wheel is turned left, so I deduce the noise origin is either, wheel bearing, cv drive shaft joint wear, tyre problem, diff problem, brake caliper /disc/pad rubbing or catching as ALL these revolve in direct proportion to road speed, I'm inclined to think its the bearings but they need pressing out and new pressed in unless I obtain a complete hub off a scrapper for a more straightforward swap over, the noise is getting quite intrusive now with tingle /vibration through the steering wheel. |
